I have a # 2 Marsh hand plane that is in good shape. I sharpened it today and now it is chattering real bad. It does it on very fine settings. Any ideas what might be wrong?
Double check that you reassembled everything correctly and that there isn't something between the iron and the frog. I have had this happen and it was a reassembly issue.
Hand Plane Chatter
Thanks for your help. I did have a loose screw on the frog. All is good.
