you need to spray
it in the sheen that you desire. in a dust free environment and by someone that knows how to spray, so that it doesn't need rubbing out.
there are different finishes to use that overcome your problems
ron
Sheen
Mr. White
The look you're after can be difficult to achieve rubbing out a patterned top i.e. sunburst. You can try sanding up to 1200 followed by finest steel wool and wool lube paste, but wait a month after finishing to rub out.
Second option - sand last coat up to 1200 - followed by one last satin coat -let it cure - no rubbing -
SA
Aside from the good advice for getting the satin sheen you want by applying a coat of satin varnish, I will suggest that you have nowhere near removed the wax you applied by using soapy water. You will need to use mineral spirits and change your rags often. if you don't remove all of this it will compromise your final coat of finish.
And a ROS sander doesn't have a place in a final sanding.
rubbing out
Hi
I have seen your post on a few forums and the answers are missing the real problem.The problem ls in the finish you have chosen. Cat Lacquer was designed for kitchen cabinets[vertical surfaces].It is not designed to be rub-out. And when applyed to furniture is considered a one way finish,not repairable and very hard to remove. Many furniture co. are using it on furniture because it is fast to apply . I have discussed this problem with others on the SAPFM Fourm, http://www.sapfm.org/forum/index.php?topic=1909.0 This is my first post on this forum,sorry its bad news,but maybe save you some time. Randy
