Does anyone know of a source for handscrew hardware? I know I’ve seen it in the past, but I can’t find anything anywhere now.
Steve,
Wouldn't it be easier/less expensive just to buy some? Woodcraft is selling 12" handscrems for $23 ea.
Steve,
Well, went to Woodcraft for another look and found this: http://www.woodcraft.com/family.aspx?FamilyID=4386 for $17.99.
In the Closeout ( http://www.woodcraft.com/family.aspx?familyid=318 ) they have 'em for $22.87!
Go figure!
Easier? Sure. Less expensive? Hard to say--it depends on how much the hardware costs. I just happen to have a source of inexpensive 10/4 straight-grained beech.
I bought some about 20 years ago. I felt it was a waste of time and money tok build my own.
Steve,
Go to the Jorgensen company website, I think it is "Adjustable Clamp Co." They used to sell handscrew kits.
Best!
-Jerry
Thanks. Their website isn't responding right now, but you gave me an idea: Instead of searching on "handscrew hardware," I tried "handscrew kit," and got lots of hits. There are some frighteningly inexpensive ones sold by Grizzly et al. (available via Amazon.com--only one middling review), as well as some more expensive ones available from Woodworker's Supply that are supposed to be the "same" as the ones in the Jorgensen clamps. I don't know if "same" means "identical" or "equivalent."
Never used these from Rockler, so I can't speak to their quality, but the price looks right.
http://www.rockler.com/product.cfm?Offerings_ID=18917
Those wouldn't allow me to use the aforementioned 10/4 beech that I have such a plentiful supply of. ;-)
saschafer,Perhaps a bit more innovation...if you could buy threaded rod that worked.. and.. http://www.rockler.com/product.cfm?page=367
What o you think?
Handscrews rods aren't just threaded--the two ends are threaded in opposite directions, left-handed on one end and right-handed on the other.
Ahhh...there's the rub, thanks for clarifing
Grizzly has them in their catalog or online through their Amazon outlet.
Bruce
Jorgensen used to make hand screw kits that had the screws and hardware and you supplied the wood. I bought a few at a woodworking show. They showed them on the Jorgensen website but gave know details so I don't know if they still make them. I liked the idea because I could use up scrap wood to make more clamps. You also might try e-bay they often have various brands of handscrews at some pretty good prices.
Troy
I recently bought some kits at Taylor Tools. The instructions recommend use of a drill press which I do not have. I used a brace and bit for the holes drilled through the face, drilling from the reverse side once the bit screw just poked through (to reduce tearout). I used a power drill and a 15 degree wedge to drill the inside, angled holes for the threaded rods (I clamped the pieces on top of the wedge and bench.). It worked okay. After epoxying the hand grips, I wonder if it is really necessay to drill through the ferrule to drive the pins that came with the kit? It seems like the drill bit will just run into the threaded rod. I don't see how the ferrule can go anywhere and seems tight now.
Here's a link to the kits..
https://taytools.com/products/copy-of-wooden-hand-screw-clamps-for-woodworking-2?variant=39382338895959
Pin would provide backup if the threaded rod ever tried to un-thread itself from the epoxy, and take some of the strain to discourage that from happening in the first place. But I guess you could wait for the epoxy joint to fail, if it ever does, and pin it then as repair...
Thank you Loxmyth.
This thread is from 2008.
“[Deleted]”
