I know this has been asked before. Can anyone direct me to the right thread? I have a Jet contractor’s saw, and the blade height and angle adjustments are rough and have a ton of slop before engaging. How to adjust these devices?
The only adjustment I have found is to get the blade angle/tilt to zero. Mine is not too bad if I keep the gears fairly clean. Unfortunately thats just seems to be part of the required maintenance. I've learned to always set the height on the rise and the tilt in the same manner. My maintenance has been to just vacuum it out well, hit the gears with some WD-40 and then a light shot of "spray on" white lithium grease. I do this about once a month or whenever I start having problems.
Steve - in Northern California
Edited 4/29/2002 11:52:10 AM ET by Steve Schefer
Maybe I'll try Jet tech support. They are usually pretty good. There must be a Jet approved fix for this. I already use the "raise only" method for sneaking up to final blade height, which kind of ####. I'll let you all know what they say.
qsawn! Dizzy's Shop web site has a page specifically addressing this problem. Go to:
http://home.pacbell.net/jdismuk/jetfix.html
Good luck!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Thanks Forest Girl. I knew I had seen this someplace, couldn't think where. Will try it soon and post results.
Q-sawn
Let us know how long this procedure takes. I need to do it too.
This looks worse than filing a tax return. I'll get to it sometime soon, let you all know how it goes. Antbody else tried this?
Mine is not so bad as to warrant the downtime right now. I'll do it in the fall when the crooked board moisture meter tells me the wood's gonna turn on me. I would estimate that it would take about 10 hours of uninterupted (yeah right) work. The actual fix is not all that difficult its getting to it that's bad.Steve - in Northern California
Given my current situation, full time job, remote shared shop location, and three kids under 7 years old, hmmmmm. 10 hours work = 6 months. You know, maybe this sloppy handwheel thing is not so bad!
Pretty much my thoughts too. It frustrated me a bit at first but it doesn't bother me anymore so I say..... Let it be, Let it be, Let it be, Let it be... Steve - in Northern California
That is a problem with the design of Constractor Saws. The way the tightening mechanism works, it draws the raising mechanism against the fixed trunnion.
Two suggestions. First, tighten the tightening knob, then back it off just enough to allow the raising and lowering of the blade. This way almost all of the slack is out of the mechanism. Try "rocking" the raising and lowering wheel as you tighten and loosen the knob and you will see how the slack is removed.
Second, set the height by cranking the blade up, not down.
