This question is about the cabinet hanging rail which most cabinets have along the top of the case back. I don’t want to confuse this with the “hanging cleat” or “French” cleat which has been posted recently.
What is the fastest or “proper” way to build in the cabinet hanging rail ? I make my boxes with recessed backs, all carcase joints are dadoed or rabbeted. The sides are dadoed ½” and setback a ½”. The hang rail which I use is ¾” and rabbeted on both ends so as to sit in the side dadoes and also this rail is rabbeted on the bottom so as to cap the ½” back panel. Now this is all real strong but a lot of operations to complete. I wonder if I can streamline these steps and still get an equally strong box? Since all my joints, as I said are dadoed and rabbeted, I wonder of I even need a hanging rail? Can I just screw through the ½” back, through a spacer and shim into the wall stud? I know a lot of cheap stock cabinets are done this way but I hope to get advice on the conventional practice from custom workers. (I don’t mean to offend anybody but I really don’t want to hear about biscuits and pocket screws, I just don’t trust them where structure is required).
Additionally, I have been rabbeting the top edge of the base unit side panels to set in stretchers. Would simpler corner blocks be sufficient instead of stretchers? If so , how best to fasten? Thanks for advice.
tc
tom,
Not sure this a faster or the "proper" way, but here's another way to install the hanger rail: I use 1/2" Baltic Birch for drawer sides, so always have some leftover scraps. I cut the hanger rail 1" less in length than inside cab. measurement. Glue & screw a piece of BB about 2" X 6" to each end of the rail (screws go into the end grain of the rail). Then glue & screw thru the opposite face of the BB into the cabinet side. It's not the best looking way to attach it, but if you bevel the edges of the BB pieces, it doesn't look too bad. GP
