I want to install a bookcase using 3/4″ shelving to a wall with my keyhole bit. can you come-up with a fixture that will allow me to do that?
I have a plunge base and a fixed base router. I’ve read your article on “mounting panels with keyhole slots”, but I’m only working with a panel thats 3/4″ thick!
Any suggestion would be of most help!
A couple of questions: Is the piece that you read about making slots from methods of work in issue #134?
Second, I'm not sure why you would have a problem with the panel being only 3/4" thick, unless you are trying to make the slot in the edge across the 3/4" dimension, in which case a keyhole slot isn't going to work well and would have very little strength.
John White
Edited 4/19/2007 3:19 pm ET by JohnWW
