A recent issue of Old House Journal recommended applying a 50/50 mix of linseed oil and turpentine, as much as the wood could absorb, before painting trim, doors, and around windows. It’s supposed to harden the wood and make the paint last longer.
I’ve never heard of this practice. Is it worth the effort?
Janet
exterior prep
I haven't heard of that practice, either, Janet. But, I would think that it might also depend on what type of paint one is using, and whether there is a time lapse between prep and painting. I'm not sure that water-based paint would like the linseed oil, and there's a question of whether the linseed oil might need some time to cure.
Dewaxed shellac is also good as a sealer for new wood. It dries very quickly, and can be used under almost any finish.
I am not a "finishing expert" though. You might want to post your question in the Finishing section to get expert advice.
Janet,
I don't think it will harden the wood. And as Ralph says, it's questionable (to me at least) whether it has any benefits as a primer for latex paint. But I have heard old timers recommend linseed oil and turpentine as a prep for windows before glazing, as a sealer or base coat under putty or glazing compound. Supposed to make it stick better, and/or prevent rot.
Linseed oil, boiled or otherwise, supports fungal growth. I once had a job building a number of park benches for our local Parks Commission. I intended to treat the white oak they were made from with a wood preservative that was on the market at that time. It was back-ordered and didn't come in when I needed it and the guy in the paint department of the local lumber yard suggested the boiled linseed/turpentine mix. I used it on the first of two runs of benches. I didn't have enough saw horses to handle so much material and used the handrails on the corners of our porches for finishing/painting that first run. We have wrap around porches on three stories so it offered a lot of extra finishing space. I wasn't worried about getting the oil turpentine mix on the hand rails and was a little sloppy but did wipe it up. The preservative came in by the time the second run of benches was ready for finishing.
Within three years that first run of benches had mostly rotted but the others lasted more than 15 years. The railing on my porches also rotted and I wasn't able to do anything to stop it, though I tried. It turned into a real expensive lesson.
I've read many acounts that indicate the the oil/turps mix penetrates the surface more than paint alone would and therefore promotes better adhesion of oil based paints. I can't imagine that it would do anything for latex paint other than make it peel. I also can't imagine that this process would promote better adhesion than a high quality primer.
duplicate
Oil does not appreciably harden wood except at the very surface
First oils used in wood finishing don't get hard enough to appreciably harden the wood fibers that they saturate, but technically, once fully oxidized and polymerized, they can harden the fibers somewhat--in the same snese that getting some model airplane glue on your skin hardens your body. A Linseed oil can eventually harden this way but it takes many months. Most oils never polymerize enough to become what any rational person would call "hard." But even this minute amount of hardening, however, doesn't harden the wood in any practical way simply because a wood finish, even a so-called penetrating oil, doesn't penetrate the wood more than a thoudandth of a inch below the surface. Oil treat some wood and then sand the finish and see how thinly it penetrates.
The recommendation on Old House was not only contriandicated (see posts above about fungal growth and preventing waterbased finishes from adhering well) but based on bad science, as in no science at all. Just a lot of hooey about which threy should have done better research.
