I’m building cabinets that will have large sliding doors (each one about 80″ tall and 28″ wide). I’m looking for hardware I can use to hang these doors. Ideally, I’d like to hang the doors from the top only. Does anyone know where I can get this kind of hardware?
PM, Google up http://WWW.Hettichamerica.com
for sliding door hardware. They manufacture Grant hardware
If the doors are bi-parting,the track you'll need is I beam in cross section and the trolleys each have four wheels. (They WON'T jump the track.)
The trolleys come either flush mount or top mount Top mount is best as you don't need to attach them from inside the cabinet. If the doors are bi-passing,you'll need a double I beam track.
Being that the doors are 80" high and 28" wide, they have a tendency to 'skitter', so attach the trolleys as far apart as you can.
Attach the pulls lower than normal on tall doors that eliminates skittering too. (33" above the floor perhaps?)
The bottom guides should be an upturned T ,type that fits a groove cut along the bottom of the doors.
You'll have to add a 'facia' across the top to hide the hardware from view. Steinmetz.
I use Johnson for all pocket doors. Here's the bypass stuff.
http://www.johnsonhardware.com/sdindex.htm
That looks perfect. Have you used this hardware to build doors that are only attached at the top. I'm hoping not to have to use a bottom track.
Nope. Only the pocket door hardware for interior doors. They don't require a bottom track as they are partially within the wall so it gives lateral stability.
If you don't use a bottom guide,the door will
rock fore and aft and will feel like a sloppy fit.
Also, by abrading the inner pocket wall,
it creates scratches and gouges
If you dont want to cut a groove along the door bottom,
for the upturned T shaped guide, (Which only show's a little)
You can use nylon U shaped guides
that ride along both bottom sides.
Steinmetz.
The Hettich brand (Grant)is made of heavy gauge material
and are standard so, replacement parts are always available.
