I recently came across a few logs of Laburnum which I plan to use in a number of turning projects. Sources say that the leaves and seeds of Lab. are very toxic if swallowed but I can’t find any info on health risks from ingesting Lab. dust from cutting or sanding. Does anyone have any experience or information sources on the hazards of working with Lab.? I hate to see it go to waste because the wood is quite beautiful. Thanks to all who reply.
007, laburnum contains a poisonous alkaloid (cytisine) which is found in all parts of the plant, but primarily in the seeds and foliage. Some rodents will eat the bark and twigs...so, apparently it isn't drop-dead lethal to all animal life.
Just the same, though, I'd be very careful with this wood. If you're going to turn it, wear a respirator and keep your skin covered. And most definitely don't make anything that is toy or food related out of it.
Jon,
Good advice, thanks.
I have turned a lot of laburnum over the years. I have found that it seems to irritate my respiratory system and skin similar to some tropical woods.Not really badly but enough to treat it as a potential problem and once sensitized who knows.Turning dry wood and sanding I use a mask, long sleeves and dust collection.I also clean up afterwards.
Jako,
Thanks for the insights. Sounds like it is a mild to moderate irritant but certainly not deadly. I'll take the same precautions and if I have a stronger reaction, I'll do another posting.
Keep in mind that different people have different reactions to irritants. I've never been bothered by any wood I've turned or sanded. But I get at least one student each year who breaks into hives or worse while sanding anything from walnut to rosewood. And I have a student right now that had to drop the class altogether because he couldn't tollerate ANY fine wood dust.
So most people don't find Laburnum dangerous. But you might. Be careful.
4DThinker
Good point - I will watch closely for any reactions.
