I need to heat my 600 sqft shop. I am in there most days, so I want something I can leave on 24/7, but turn down over night. Something energy efficient is also a must.
Any suggestions?
Any suggestions?
Where are you located? Is the shop insulated?
I am located just below Fergus, Ontario (Canada). Yes, the shop is insulated. It was once heated with oil, however everything pertaining to that has since been removed.
I assume you have access to natural gas (or at least propane)? If electrical rates in Canada aren't too different from what they are in the US, a heat pump would be the most efficient, but wouldn't handle the coldest winter days. A "dual fuel" heat pump (one with supplemental gas heat) is probably the best alternative. (That's what I have to heat my house in southeastern Ohio, by the way.) I believe they come in sizes appropriate for a small shop.
My first shop was about that size and I used a "milk house" electric heater that ran on 220volts, it had a thermostat and safety tip over switch. I used it in an insulated garage and at times the chill factor was -40 degrees F and I could always keep the shop at 68 degrees. It was purchased from Grainger and was rated at 3000 Watts. The heating coils never get red hot like other type heaters, the wire is much thicker and gets hot but not glowing which I liked around sawdust.
Buy a pellet stove.
Any brands you would reccommend??
Robin,
Have you thought of a mobile home furnace? I bought one used from a local plumbing & heating contractor ($100). It uses #2 heating oil, very efficient.
Yeah it might be back to oil but may work for you. I live in northern New Hampshire and last year I burned just a little over 125 gallons toheat a well insulated ~320 sf woodshop.
I use a gas fired blue flame heater, unvented.Been using this heater for about ten years now in my 600sf shop.Most of the time i leave the setting on 1 overnight.Their are five settings up to 32000 btu's. On the coldest days ( low teens and single digits) the 3 setting is used. Never had the heater all the way up to 5. I work in a tee shirt on all but the coldest days.
mike
About my size shop.. One of them birthday candles about 3 inches around should do but thenj again they were ment fer years of burning.. I feel for you.. I get cold if it is 80 degrees and a cloud blocks the sun!
I use a natural gas unit heater in my shop. (An attached three car garage ~ 600sq ft + 12ft ceilings). It cost around $2700 to install, but it's cheap enough to run. I keep the shop at about 10 C, and turn it up just before I go in, turn it down when I leave.
Since you plan on running it all the time, get yourself a good heater. Avoid construction heaters at all cost. Fire waiting to happen.
I use a direct vent kerosene heater to heat my 24 x 32 shop. It works very well, has over 90% efficiency and takes up very little space. Here is the link to the web site. I highly recommend them.
http://www.monitorheaters.com
Bogie
