I’m making a stand for my newly purchassed scrollsaw. What should be the height of the table of the scrollsaw for stand up use? Are there any negatives for positioning the SS for sit down use?
I see no negatives for sit down use. I have a SS that I use for about 3 or 4 days straight once a year making Christmas decorations. I only use it sitting down because I find that most comfortable. I clamp the ancient Craftsman saw to small table 21 3/4 inches tall and sit on one of my porch chairs. Comfortable and I can easily see the workspace. ...Tom
Standing or sitting set it a couple of inches below elbow height so you can comfortably control the work. No downside to sitting if it's comfy for you.
I make everything sitting height if I can. As MJ said, a couple inches below the elbows is just about right. If you're making the stand you can always adjust the height after.
Thanks Tom and MJ. Good, useful advice. I've ordered a Grizzly 60969. As a rule I've never been big on Grizzly tools but this model got such good reviews I decided to give it a try. I like to do intarsia and inlays. Here to fore I've gotten by with an ancient Delta that I inherited from my dad. It has a long cast iron arm and a spring loaded blade return. It gets the job done but is a pain to work with. Joe
I put mine at elbow height for when I stand-up, I have a high bench that allows me to work sitting with the elbows at the same height. For a posive experience, note that the blade choice is the key, there is a variety of scroll saw blades with wild tooth configurations that really can perform amazing cuts.
Fretting, scroll sawing, and marquetry are typically done sitting down. Do it standing up, and it won't take you long to figure out why.
