There’s an article on the FW database that I had and now can’t find. By Mark Duginske on cutting dovetails on the tablesaw (and bandsaw). Anyone can direct me to it? Thanks.
Is it the one where he had a TS blade specially ground at 22 ½° ? If so it's Issue #96 and the article starts on page 66.
Edited 8/22/2009 9:39 pm ET by KiddervilleAcres
Thanks but no, not the one. In this one, he used an adjustable tablesaw jig with a series of wooden spacer blocks to space out the cuts, and for the pins he angled the miter gauge with those same wooden blocks. I already did it, made the jig, had it come out successfully, and patted myself on the back. But I lost the article and now all I can do is scratch my head because the devil is in the details, and I'm getting into an increasing number of senior moments.
https://www.finewoodworking.com/Workshop/WorkshopPDF.aspx?id=2264
From Fine Woodworking #96
Is this the one?
He also put it in his book "Mastering Woodworking Machines (Taunton Press).
Absolutely! Thanks so much.
A start?
http://www.youtube.com/watch?v=N2j4uyzOVlk
I wonder.. Some cut the slice on the side next to the fence and others do it away from the fence, Which is better?
Edited 8/26/2009 6:35 am by WillGeorge
I guess you posted the wrong youtube # - doesn't seem to be related the the thread.
Yep I'm old and sort of brain dead! Sorry!
Will,
I got the right article just another technique. I should think using a special ground blade with Mark Duginske's jig/technique would work quite well. That way the teeth of the TS cut clean angled corners on the tails.
