I have recently completed faux graining a cabinet and went with an orange shellac for an authentic look. Now I am having second thoughts and think I want something more durable. Any suggestions or hints what I can put over shellac. There is no way to remove it without removing the graining, as I used a vinegar and honey glaze.
Melissa
You can topcoat shellac easily with any oil-based (alkyd) clear coats, including traditional varnish or urethanes. You can go right over the shellac in any low stress areas, but for best adhesion you should scuff sand the shellac with some 320 grit wet or dry paper and mineral spirits.
*You can use Moses T's Gunstocker's Finish or St. John's Wax to protect your shellac finish. Available from ilovewood.comStephen
*your message is from october; this answer might be a little late. but: paste wax is a great finish for shellac. 5-10 coats have been recommended to me. i did 5 on my last project over shellac. i love the way paste wax looks!!
*I would recommend not covering your shellac with poly type varnish. Shellac contains wax and poly has very poor adhesion qualities therefore you run the risk of the poly flaking off. Regular varnish has better adhesion qualities and may be an alternative.
*Shellac on a cabinet does not need protection other than perhaps a wax topcoat (Fiddes or Mylands). Shellac on a tabletop might, but I wouldn't. It's worked well for hundreds of years by itself. Don't shrink wrap it in polyurethane.
