I have acquired this gouge when I purchased a used lathe. Don’t know if its a bowel gouge or a spindle gouge. Can anyone help me figure out what it is please?
Thanks in advance.
Mark
Definitely not a spindle gouge because the flute is too deep.
It looks like it might be a roughing gouge that's been sharpened like a bowl gouge.
But I'm just an occasional wood turner so I'll defer to those with more experience than me.
Bowl gouge, finger nail grind.
Absolutely, I have three of them, some I shaped myself from a straight face to this fingernail shape. A vari-grind grinding jig is almost a must to sharpen quickly and accurately.
Can we see the rest of the gouge, especially where the flute transitions into the handle?
“[Deleted]”
That should NOT go anywhere near your bowels, but it is great for bowls.
This is a great tool with which to get familiar early as you can do an awful lot with just this one, ground that way.
It's on the skinny side for a bowl gouge so may not be the best tool in the rack
Lol. I didn't even notice the original spelling.
LMAO!
Looks like a spindle roughing gouge to me, but with a fingernail grind as others have said. The shot of the end - it looks a lot more like it was bent from flat stock, instead of a flute milled from round bar stock. If it's just a tang into the handle - and not full-section round stock - it's a roughing gouge, and SHOULD NOT be used on bowls, it doesn't have the strength at the handle. Nor is the grind really right for it - it's been modified so maybe it'll work "ok" if you know how to use it as a bowl gouge, but I still wouldn't recommend it.
Exactly
If we could see the whole gouge, nut just the cutting edge, we could tell for certain if it's a spindle or bowl gouge. It's the shaft that makes the difference, not just the edge.
Hope this pic clears things up
100% spindle roughing gouge
Agreed.
Yes - now we can see more, I agree too.
Yup. Do NOT use that on bowls. It looks like a fine spindle gouge though.
If that's the only one it came with, I'd grind if back so the sides aren't swept back. Flat across the front with a 45ish* bevel. It'll be more useful that way.
Agree - it will tend to drag in use if not ground down some.
