I have a dining table, mahogany, stained with a nitrocellulose lacquer finish, on which a plastic table cover was placed wrong side down. It seems to have “melted” into the lacquer, leaving an inverted pattern of the cloth weave in the lacquer. The indentations are widespread over the table top and deep, but not fully through the lacquer or stain. Can anyobe suggest a method to repair this finish. The manufacturer has suggested sanding down, re-staining and re-lacquering. I am not keen on that — it has to match a room full of furniture. Could a lacquer leveller or other solvent work? Perhaps followed by a new top coat?
Whats happened is that the solvents put into the vinyl to keep it pliable (plasticizers) soften the lacquer (they're in the same solvent family as lacquer solvents).
We get this type of damage a lot with movers. (But it's caused by heat in the van and the textured blankets used to wrap furniture)
Wet sand the finish with 400 grit --- but don't linger in one place or be aggresive as you don't know how thick the clear coats are.
Spray one coat of lacquer with some retarder added so that it stays wet and bites into the old lacquer. Then after a day spray three coats clear lacquer. Then rub out --- first levelling with 400-600 then polish up to the sheen you want.
Jeff Jewitt
*Jeff, thanks for the advice. I looks like I need to set aside some time for this -- will try it over the upcoming holidays. Can you suggest a lacquer product with retarder in it?
*retarder is a slow drying thinner that you add yourself--you buy it separately and add a small amount to your lacquer finish as you prepare a cup to spray.
*Ahh, the joys of film finishes. Follow Mr. Jewitt's advice.
