I just bought a nice Husqvarna 18″ Rancher chainsaw (it accepts up to a 24″ bar) and I’d like to purchase a ripping chain for it in order to do some crude lumbermaking. I’ve got 2 good sized Ash trees in my back yard that are storm damaged that I will now cut down. I would love to slab off some big greenwood beams to dry and use them later for shop projects requriing heft (bench bases, etc…). I know standard chainsaw blades have too many teeth because they are for crosscutting. Thanks for any help.
these guys have it, you may have a hard time finding it in the online catalog - give them a call on Monday - http://onlinestore.forestindustry.com/cgi-bin/baileys/catch.html?id=HYLBiIVi&product=new0189
Bill you can use a standard chain to give you a fairly decent cut. A rip chain is only about the width of the bar and break fairly easily unless used in some sort of saw supporting device like a Alaskan Chain-Saw mills or a chainsaw saw mill. If you are planning on milling a lot of lumber than you should look at a bigger saw. I burned up a Husky 62 a few years ago doing just what you are planning on doing. The saw you have if I can remember right is 55CC and will have to work pretty hard to do any amount of ripping.
I have attached a picture of my dads chain saw mill.
Scott C. Frankland
"This all could have been prevented if their parents had just used birth control"
I use them weekly in the freehand mode with a 36" 046 Stihl and don't recall one ever breaking.
My mill only takes 7' diameter logs and many big cedar buttresses are bigger than that and have to be lopped off first.
baileys-online.com in CA and TN....by far the best prices anywhere.
While I also strongly recommend a simple Alaska Mill for slabbing, I do a lot of chainsaw carpentry with them as a way to efficiently use cedar sawmill waste.
Bench
Chairs/Tables
Edited 11/23/2003 12:21:35 PM ET by Bob
