Help needed from fellow Bosch Slide Compound Mitre 3915 needed
Recently acquired a used Bosch 3915 slide compound mitre saw. Great saw but missing the lower guard. I have ordered all the parts to install the lower guard…except.., the guard linkage, part # 2610911557. Neither Bosch service nor parts stores have one..listing it as discontinued. I even contacted Bosch service techs for specs so I could make this piece… they only had the same parts schematic I have. If anyone has this saw and can trace an outline of this part on a piece of paper, or give me the actual measurements of the slide hole and the distance from the slide hole to the back hole with the shoulder screw, it would be greatly appreciated. The parts schematic I have gives me a rought idea but not actual measurements.
I tried to locate a bosch tools forum, but it appears the only one is in German… so thought I would try fellow woodworkers.
hi, i would like to no if you found the pieces because im still looking for it to and it seems that no body has it even Bosch?
thanks
Woodracer88,
Did you ever find this piece? I have a bosch 3915 and I do have the linkage piece. However, I modified mine a bit due to the tremendous resistance it caused. Let me know if you are still looking and perhaps i can provide some measurements for you. There is an offset in the piece so it isn't a simple flat piece.
woodracer88 wrote:
Recently acquired a used Bosch 3915 slide compound mitre saw. Great saw but missing the lower guard. I have ordered all the parts to install the lower guard...except.., the guard linkage, part # 2610911557. Neither Bosch service nor parts stores have one..listing it as discontinued. I even contacted Bosch service techs for specs so I could make this piece... they only had the same parts schematic I have. If anyone has this saw and can trace an outline of this part on a piece of paper, or give me the actual measurements of the slide hole and the distance from the slide hole to the back hole with the shoulder screw, it would be greatly appreciated. The parts schematic I have gives me a rought idea but not actual measurements.
I tried to locate a bosch tools forum, but it appears the only one is in German... so thought I would try fellow woodworkers.
bosch guard likage
I'm looking for the part. Can you please provide measurements to rkillam@comcast.net
Looking for part number 2610911557
I am missing this part also. If you could provide some measurements I have a great machine shop in town that can make one for me. Your help is sincerely appreciated.
I am curious if you ever got this part made?
I am about to get a new Guard linkage made myself and wondered how it worked out for you?
My original is a bit deformed so if you recurved a good tracing that would also be very useful to me.
Any help sent to martinreisle@gmail.com
Is very much appreciated.
I'm also in search of the guard linkage. Does anyone have a diagram with dimensions?
We’re you able to get that arm design somewhere for your Bosch saw ? I’m in the same predicament as you were with my Bosch saw
I'm debating just throwing it away. Can't find parts and hands/fingers worth it
