Hi,
I’ve just finished constructing a full set of kitchen cabinets. I’m intending to purchase the doors and drawer fronts. If I intend to leave the cherry a natural, just a few coats of wipe on poly, do I need to pre treat the wood, and if I do, what should I use?
Mike.
Dewaxed shellac. Zinseers Seal Coat would be good.
I disagree. If you want the natural cherry look (which is what I do with all my cherry pieces), there is no need to use a shellac first coat. The first coat of poly will act as a sealer. Sand lightly after the first coat, a couple more, then you're done.
If you want a deeper initial tone, then a coat of boiled linseed oil will do the trick. (Make sure to let it dry for a few days before continuing)
Otherwise, let nature do the deeping for you.
(Nothing against shellac, I use it quite often myself. But why use multiple finishes when you don't need to?)
