Okay, call me stupid, but I spilled a few drops of Clorox bleach on my antique dining room table top. Now I have a “beautiful” white blotch.
Any and all advice on how to remove this color and/or cover it, will be
appreciated.
Joan
Sight unseen it's hard to diagnose finishing problems, but from what you said I'll give it a try. If the table is truly an antique, chances are that it was finished with shellac and polished with wax--both of which are highly susceptible to moisture damage. I suspect that the "white blotch" does not go deeper than the finish, which means it will probably be fairly easy to fix. Try this:
Dampen a clean cotton rag with denatured alcohol and rub the damaged spot vigorously in a circular motion. Repeat this process 2 or 3 times, then let it dry for 30 minutes. That should do it; if not, youre in for some serious refinishing work.
