Help with asymmetric quarter pipe
![](https://secure.gravatar.com/avatar/cf2aa25f9fbe214863c8397d29333a3f?s=52&d=https%3A%2F%2Fimages.finewoodworking.com%2Fapp%2Favatars%2F200x200%2Fh.png&r=g)
I am trying to create surface that is basically a tapered concave quarter round. The length of the “pipe” is 42 inches and the top has a radius of 8″ and the bottom is 3″. Can this be done in sketchup? If so, does anyone have any idea how I might accomplish this? I have attached a .pdf of the general idea. Many thanks for your help Hastings
Yes, this can be done in several ways. I'll see if I can make some examples and post them.
Would anything be in same plane? In other words would this have to lie on a flat surface?
Dave:
I have attached a .pdf of the sketchup file so you can see the context. I am trying to make a seat back for a kitchen corner that is common in english pubs and this is the piece for the corner. I need to also round over the ends but I assume that once I have mastered this I will be able to do the convex shapes.
Your sample looks exactly right.
Thank you so much for your help.
Hastings
PS I have added the file to my original post as I don't see any option to attach files to a reply.
Ah, good. Now I see how you are trying to use it. So for what I did, I drew a "cove molding" profile with an 8" radius on the arc. I extruded it 42" with Push/Pull. I deleted everything but the arcs and the faces and edges between them. Then I selected one of the arcs and in the entity Info box, changed the radius from 8" to 3". After that it was just a matter of moving that arc to the right position. Guidelines made that a cinch.
You could also use the Scale tool but that's a bit trickier when you need to get the arc to be just the right size.
Are you planning to add individual slat components around that corner?
Dave:
I've uploaded another
Dave:
I've uploaded another file showing the corners completed using your technique. It worked perfectly. Thank you for you help; I really appreciate it.
My plan was to make it out of a single piece so it became a feature, rather than make it of slats.
Hastings
Good, good. And you did it three times. I'm glad that worked for you.
I think your idea of making those features is excellent. I'd like to see the finished project.
Dave
Would this work for you?
http://farm3.static.flickr.com/2625/4229141066_89e960ccef_o.jpg
