A mishap caused my carbide tip Lenox blade to be unusable. It is 149 inches long and 3/4 “wide. A new one is $150.00. Is there a blade of this caliber someone could recommend that would be less expensive?
Ken
Ken
I think it'd be helpful for us to know why you chose that blade originally -- e.g., what type of cutting were you doing that you felt you needed a carbide-tipped blade?
It was recommended by Jesse at Eagle tools. It really
cuts quickly where regular blades struggled. If I could
find a less costly alternative I would be more than pleased.
I was cutting a log and let it roll into the blade causing it
it kink. Too bad that had to happen to the only really great
blade I had. The regular blades just do not compare.
Ken
If you're determined to use a CT blade, probably best to build a carriage for the logs to make sure they don't roll. Otherwise, you're losing any monetary advatage to milling your own wood. :-(
forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
Forest got it...build a carriage for the logs to make sure they don't roll!!
No kidding. Have to say, even with a sled I can't imagine putting a $100+ blade in a situation like that! The chances of something happening are too big. If I had to work a little slower, and use a reasonably-priced blade, so be it. Save the carbide for squared lumber.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
Forest.. I'm a man and lives on the edge! LOL....
Forest is so sweet for a woman!
Edited 3/25/2005 10:12 pm ET by Will George
If you're cutting from logs, is the blade so badly kinked it won't cut or track? If you're rough cutting, will it matter?Can you work the kink out on an anvil?Good luck,Leon Jester
Tried to but no luck. I can barely see it. It actually
looks all right and I don't know why I can't get it to align on
the wheel. I have an 18"Aganazzi and I'm not very mechanical.
Any ideas?
Ken
Have you checked to see if your wheels are in alignment with each other and that the bearings are ok and that the wheels are properly balanced?Might want to look at the tires to see if there's a chunk gouged out somehow.One of the older issues of FWW has an article on bandsaw alignment and tuneup, if you can find it, it may be of some help.Good luck,Leon Jester
Thanks. The blade I installed after the fiasco tracked
fine. The wheels on the band saw are substantial and
not likely to move....I think?
Ken
That would tend to prove that one.Pity about the carbide blade, Ken. It might be worthwhile calling the factory to see if it could be mended. Worst they can do is tell you it can't.Leon Jester
Hi
I use Lenox Trimasters, too. Exensive, though. Simmonds do a similar blade, but I don't know about pricing.
What about the WoodSlicer that Highland Hardware do? (http://www.tools-for-woodworking.com/index.asp?PageAction=VIEWCATS&Category=295) I've heard good things about them, although they ain't going to last as long as a carbide tipped blade, they are a lot cheaper.
Kipper
If you really need a carbide blade, I don't think you will find one for appreciably less money.
It is very possible that your blade may be useful again. If it is kinked at one spot, cutting the blade and silver soldering or rewelding may work. Your saw may have enough up and down play to accomadate a slightly shorter blade.
mike
Mike:
Thanks to you and all who replied. I had a class in
turning yesterday from Steve Dunn and learned carbide
blades should not be used on green wood. Too bad
I didn't take the class first.
Ken
learned carbide blades should not be used on green wood..I do that! Geeeeeeee Never lost a blade doing it????
Suffolk Machinery makes one of their Timberwolf blades that is designed specifically for cutting green wood, it works very well.
John W.
Thanks. That is great to know. I suppose one of
the catalogs carry the brand?
Ken
Dovetail,
I don't know if Timberwolf blades are in other companies catalogs, but you can buy directly from Suffolk Machinery, so you can avoid going through a middleman. Their web address is suffolkmachinery.com or you can call them at 1-800-234-7297.
I'd recommend calling, the web site isn't all that well laid out, being primarily set up for their industrial customers. On the phone, the techs at Suffolk Machinery are very helpful.
John W.
John:
Thank you very much. I just ordered a blade.
Just imagine that your kink was a snap, and take the blade in to get welded. The last one that I had welded came out 1/4" shorter and it cost me $6.00. Peter
