Yesterday I was staining some cedar in my garage with Solar-lux alcohol based stain. I tried to keep a wet edge but it soaked into the cedar so quickly that if I left an edge unattended for more that about 30 seconds I got lap marks.
Is there anything I can do to even things out?
Rich
Rich,
You can spray the stain. If you don't have spray equipment, there are are very low-priced simple spray "guns" available for this sort of use. I've even seen "one-shot" versions at Ace.
You could also try a method that "retards" shellac. Add a small amount of turpentine to the alcohol mix. I believe it works by slowing down the alcohol evaporation. I don't know if that will help with the lap marks due to the rapid absorption.
A sealer coat of a very light cut of shellac may also help.
VL
you may re-wet the areas with straight alcohol to dilute the laps..ought blend fairly well, if the color can remain in the vehicle long enough to redistribute.
Thanks to all for the responses.
I talked to a friend who suggested almost the same thing. He told me to mix the alcohol 1:2 with water and use that to blend. He figured that the water would slow the evaporation of the alcohol. It seemed to work fairly well.
As for using oil or water based stains, I appreciate the input but this project is a kayak that will be given a clear coat of fiberglass and ressin. The ressin is not compatable with oil based stains and the water based analine dyes (which I love) are not UV resistant.
Thanks again
Rich
Rich,
Just a note concerning the fading properties of dyes. The information that water-reduced dyes are not as lightfast as solvents dyes is out of date. Whether reduced in alcohol, acetone, or water, some dyes are more lightfast than others. The best performance can be expected from the metallized aniline dyes (e.g., Trantints/Transfast).
No dyes are rated for exterior use and will fade over time. Using a coating that contains UV absorbers/blockers will slow the fading.
Paul
If they aren't compatable, then use a coat of Shellac to seal the oil or water based stain. Shellac is such a wonderfull product, for an undercoat it is a universal sealer, for a top coat is a great finish product, and second best to lacquer for water resistance. It can be applied over anything, save and except wax.
Boris
If you're applying the dye by hand, take a look at how Jeff Jewitt is applying dye in the article at this link - A&C Finish. To dye a larger area, use a larger rag and keep it wet. Wet all the wood just as quickly as you can; don't try to be neat. If the dye drips/runs onto an adjacent surface, wet that entire surface immediately. When everything is wet, wring out the rag and wipe up any runs or pools.
Behlen makes a retarder that will evaporate slower giving you more working time.
To fix the lap marks, wash the wood with liberal amounts of denatured alcohol (the solvent for the dye you're using) and then re-dye.
Paul
What testimonial for oil or water based stains!
Boris
you know it! A thixotropic gel stain is so nice..hard to go back to anything else.
Go Stab yourself Ya Putz! Ya think I Parked here?
