43477.1 | ||
Hi everyone I am building a copy of this table. I would like to paint the base black as well. Which should I use oil or latex? Should I prime? Should I topcoat with a poly. I am leaning to spraying a couple coats of a satin black oil, just from a spray can brushing that out and when dry topcoating with a spray poly satin? I am leaning toward oil paint this time because the latex tends to stay soft. It can feel tacky even when dry. The top of mine is antique pine with breadboard ends. The legs and aprons are poplar. Any advice would be appreciated. Webby
Edited 9/20/2008 2:20 pm ET by webby Edited 9/20/2008 2:21 pm ET by webby | ||
– Attachments follow –
Webby
prime, sand, fill, sand, spray oil.
Real trucks dont have sparkplugs
Those legs will get kicked more often than you'd like so you'll want a tough coating. I don't know about latex - never even seen it here - but for things like this I go for for 3 topcoats of a good oil paint over 2 coats of undercoat, hand sanding between coats.
Webby:
If you're OK with spraying, and you feel a little adventurous, try automotive paint:
1. Sand to 180
2. Apply one coat of primer and sand smooth with P320 or 400 (Fill any blemishes)
3. If necessary, apply another coat of primer and sand with P400.
4. Apply two coats of black base coat
5. Apply two coats of clear coat.
6. Rub out to desire sheen
You can get small quantities at a quality automotive paint store (where the body shops go). Don't go to a retail auto parts store.
The primer is two part as is the clear coat and all involve careful mixing and short pot life.
You will end up with a deep black, very smooth, durable finish that will take some abuse.
Good luck with your project.
Hastings
PS practice on scrap first!
If the base is free of filler. Use a very dark brown stain, tudor? maybe and then finish with satin clear coat. I think "paint" will look out of place.
Thanks every one for the opinnions and advice. I am going to look at different paint options including auto and standard interior paints.Webby
I agree that "paint" is not going to look like what you want for this style of table. A black stain might do it, or shellac tinted with black could be used. You want a VERY thin "looking" black finish, in my opinion.Gretchen
Milk paint, the real kind, with an over coat of an oil/varnish mix to intensify the color and prevent any waterspotting might be appropriate.
Thanks everyone, I am trying to make a somewhat refined but old looking peice.
LIke something that has come through the years. Finish not perfect, been moved here and there and maybe even sufficed as a temporary changing table for the grandbaby.
I am still building it.
OH, the pic is from this site:
http://www.sippicancottagefurniture.com
Webby
