I have a table from the 1930’s where the leg has detached itself recently. I have cleaned it up and the pieces are ready to be mated but I am not sure of the method I should employ. I was contemplating using a sliding dovetail key but there really is not much for the key to bite into to on the leg. I also thought of two 5/8″ dowels. This may be the easiest but not sure of it’s strength relative to the pressure applied from the table itself. With that being said I belive the other two legs are attached via smaller dowels as was the one that broke away. Any thoughts as to the best method to reattach the leg? Thanks.
replace the dowels
and clean off the old glue and put it back on
ron
