Any Have a Suggestion??
I recently posted a request for some help in removing white marks in a table top finish caused from using the table as an ironing board. Looks like the heat disturbed the finish to the point of leaving “white impressions on the table” HELP Someone??
Hi Fred,
I don't recall seeing your original post, could you give use some more information to work with? The type of finish on the table will determine how you can repair the damage. Lacquer or shellac, oil or water based polyurethane, varnish or oil finish?
Since the finish turned white, I think that there might be some water trapped in the finish either from steam in the iron or moisture from the clothing that was being ironed. Lacquer and Shellac are the easiest to repair, polyurethanes generally require sanding all the way down and re-applying.
Bob
*Hi Bob,Thank you for replying to my question. This table top appears to be a lacquer finish. If it was shellac, would the repair process be the same? I'd appreciate any advice you can give me.I also posted a question regarding repairs to an "occasional" table (the posting is under table top repair in the main discussion list)The table has a circular center portion of leather with a gold embossed outer edge design. I successfully accomplished pigment/dye repairs to the center portion but there are numerous bubbles under the surface. I pricked them with a needle and ironed them out but they returned. Replacing the center portion is not an option...any other repair methods you would try? Thanks again. Fred
*For your white marks, try rubbing the spot with mayonnaise. Then there is a product called Howard's Restor-a-Finish that works wonders on white spots. Look for it in antique malls or maybe some Home Depots, by now. It is not expensive and is wipe on wipe off.
