I am finally building a real workbench and am contemplating what to use for the top. I can get a good deal on 8/4 Hickory .60 bf. Curious if anyone has built a benctop from Hiickory or if anyone had any thoughts on why not to use Hickory?
At $0.60/BF, I'd say go for it. Assuming, that is, it's good quality stock, as opposed to "rustic" (with voids, knots, etc.)
Hickory for workbench top
Nothing wrong with hickory for a workbench top. It is supremely dense. Go for it!
weighty
Well you will certianly have a hefty top. It will be worth the effort.
Good'n Strong Hard Stiff
All the right characteristics I would want in a bench. Two thoughts from the arm chair / library column of this woodworking out fit . . . :
1. Might be kinda slick ; no big deal.
2. From reading Krenov I learned hickory may be best coated with these; in order of preference first = best :
Nothing
Hard wax
Well thinned shellac. One lb cut or even thinner.
Oil tends to make the surface look sickly and unattractive.
Welp that's all I got here.
Making your own REAL work bench eh . . . you are a brave, brave man.
I've heard hickory is a bit hard to work. Should make an excellent bench top, you might get a small quantity and mill it a bit to see if it will cooperate. Don't know how it will plane, whether you desire power or hand tools.
