I glued up a windsor chair with hide glue (titebond?) and neglected to sponge off some of the drips…it has now dried and I want to remove before finishing. What is the best way to remove? Chisel and sandpaper? Warm Water? something else?
Thanks!
The Woodwrong
Woodwrong,
You can reactivate hide glue with heat. Try using an iron set to low or a hair dryer. Heat the glue until it softens and you can wipe it off.
Sincerely,
Gerald
