Has anyone tried using a small home kitchen crock pot (the small ones you can get for about $15 at target or wal-mart) to melt hide glue? The commercial hide glue pots from the tool stores/dealers are closer to $100. It seems to me that a little home kitchen crock pot should work the same, for a lot less cash… any comments? thanx in advance!
http://www.thebestthings.com/newtools/hide_glue.htm
http://www.stewmac.com/shop/Electronics,_pickups/Supplies:_Glue_pot.html
If it keeps the correct temp it will work. We've used a double boiler with a water bath and candy thermometer. They used a lot less in the old days. Whatever works!
I bought one of Target's electric teapots that had a temperature control knob. I filled it with water, put a thermometer into the water, and fiddled with the knob until I got the temperature I wanted. Then I left everything as is, and checked the thermometer occasionally to see that the temperature was relatively stable. Once satisfied, I marked the knob and pot body with an indelible ink, and then I taped the knob in position. It all works well for me. I just need a heated shop so I can use hot hide glue year round. The pot seems to hold the temperature within a few degrees of the set value.
Rival Hot Pot model 8071. As noted by following messages the glue goes in a jar, not directly in the pot (he reminds himself).
Edited 11/15/2005 9:36 pm ET by BobMc
Another inexpensive way to heat a small amount of hide glue is to use a baby bottle warmer, the kind commonly available to heat a single baby bottle.
I've used a wal-mart crock pot filled with water and it works fine. I have one with a three position heat switch and the center position keeps it around 140.
I use canning glass jars to hold the glue and the pot can hold more then one at a time so I can have a sizing and a glue jar available without having to buy several glue pot to accomplish this.
I put a thermometer in the glue I warmed with a small crock pot. It kept it right at 140 degrees, essentially ideal. Two bucks at a tag sale, or perhaps $12 brand new--either is a lot better than $100.
Thank you all for your responses.... I'm off to Target
I have used a Sause warmer and a thermater to try to control the temperature but you have to watch it to keep the temperature at 140. I like the idea of the crock pot. Does it hopd the temperature at 140? I also started buying Old Brown Glue which is available from http://www.wpatrickedwards.com . I first used it this year in a class with Kelly Mehler in Berea,Ky. It is very easy to use since it stays liquid at room temperature. I respect Kelly's opinion and Pat Edwards has extensive experience. Does anyone have long term experience with it?
Dan Evans
