Sitting here on a cold snowy day wondering…how many of you out there use hide glue? What benefits do you see in using it….or for that matter drawbacks?? And if given the choice what is your preferred glue for fine furniture construction??
All pros and no con as far as I'm concerned. Wouldn't use anything else.
It has everything going for it - strength, creep resistance, reversibility.
All the great masterpieces were constructed with it. Good enough for me.
How do you handle complex glue ups like a large carcase for a chest of drawers. Do you use urea to extend the open time. I've been using franklin's liquid hide glue more and more but for a complex assembly I am still using good ole elmers white. Tom
Douglasville, GA
Franklins is terrible. They use way too much crud to make it stay liquid. Shelf life is very short. They claim otherwise, but I think its worthless. You just have to sequence assembly so that things get glued within the working time of the hide glue. Keep the room hot and use heat lamps if you must have longer open time. Urea or salt works. I use a little in the winter if I can't get the shop hot enough. If you add as much as they do in Franklins, the stuff never sets. Any reasonable amounts still only give you 30 seconds.
Pretty much how this guy handles it:
http://www.bearmeadow.com/build/materials/glue/html/glue-measure.html
I stumbled across this a while back and post it when a question comes up about hide glue. I had pretty much arrived at some of the same conclusions through reading and asking others.
I have to admit that I've used the cold stuff without any problems. You must be cognizant of the date on the bottle. I don't use it if it's within two months of the expiration date. It takes a while to cure, but I don't have any problem with that. I rarely push a glue-up. When it's in the clamps it will sit undisturbed a minimum of a day and usually longer. There always seems like there is something else to do - not much down time for me.
Thanks for the link, very helpful. I have had good luck with franklins so far. I rarely have a bottle of glue around long enough to reach the expiration date.Tom
Douglasville, GA
I really don't think there's anything wrong with the Franklin product if you watch the expiration date. It's plenty strong for a project made with well-fitted joints.
Edited 3/9/2004 4:34 pm ET by CHASSTANFORD
The smell of real hide glue is a major drawback; I can still remember the stench yaers ago from rabbit skin glue.In restoration work, it's probably unsurpassed, and as mentioned repairs are reversible.
It is important to not to try to use hide glue in a cold shop.
Frank
Below is a posting I put in a few weeks ago, that gives my reasons for using hide glue.It was written in response to a inquiry about my dislike of yellow glue. On the issue of the liquid hide glue, I like the stuff and use it often ( I used it today in fact). It has never failed me. There is another liquid hide glue sold under the name of old brown glue at http://www.wpatrickedwards.com, I've found this also, to be an excellent glue.
I use hide glue, both the liquid and hot varieties, almost exclusively. I have several reasons for favoring hide glue. First is its adaptability, it can be used for rubbed joints, veneering, gluing fabric or leather writing surfaces, making flexible glue lines with the addition of glycerin ( such as the muslin reinforcement of highboy hoods, I've personally never done this ), extended set time glue, with the addition of urea, and last but not least extremely strong rigid glue joints. Another reason, is hide glue's centuries old, proven track record, which can't be matched by any modern glue. While I'll admit this is probably not a big deal, I like to know that the glue I use will last for not only my lifetime, but many lifetimes. Last, is its easy of reparability. Hide glue will bond quite nicely to itself, so a failed joint is easy to repair. This may sound less than inspiring, but I believe this is the reason that so many antiques survive, since all joints will at some point fail, being able to easily re-glue and end up with a strong joint is a real plus. I don't believe any modern glue has all or even most of these attributes.
Now that I have sung the praises of hide glue, here are its drawbacks. Hot hide glue gels so quickly that it can be a challenge to glue up any but the simplest project. The addition of urea will slow the gel time down, but it does have a small effect on the strength . Hot hide glue has to mixed fresh nearly every day, although I keep mine for up to 3 days in cool weather. It has a smell that isn't exactly appealing.
Liquid hide glue has to be fresh ( bottles are marked with an expiration date) or it will produce poor bonds. It is not as strong as hot hide glue, at least not initially, because the gel depressants, cause it to remain somewhat gummy for days. I too has a characteristic odor, that isn't pleasant .
I use white glue to make up the inlay bandings that are part of my work, simply for its easy of use and long open time. In the finished piece hide glue will be used to adhere the inlays. I would also use white glue if I were making things such as kitchen cabinets, entertainment centers and other items that probably won't have a long service life, where hide glues time tested durability wouldn't be an advantage.
I have gotten good results with yellow glue, but I have also had poor results. In fact my only failed joint was done with yellow glue ( Tite Bond II) The poor results were most likely from using old glue, but even fresh glue seemed to be less rigid than white glue, and certainly no where near that of hide glue. The failed joint was done with a fresh bottle of glue ( free sample at a woodworking show), so that of course took Tite Bond II off my list.
Rob Millard
TiteBond II is water resistant. Definitely softer than Titebond I. Main reason to use it is if the water resistance is desirable. If the glue has been frozen it doesn't work as well. If frozen a few times, doesn't work at all.
I've had fresh liquid hide glue fail. If the humidity is high and the temperatures cool, it can take days to dry. Never had that problem with hot glue. Also, the liquid stuff rehydrates much easier than hot hide glue. Can fail under hot humid conditions. It isn't hard to make up hot glue. It's strong, rigid, doesn't creep. You can make it strong or weak, hard or flexible, extend the setting time, even make it waterproof. Good stuff. The liquid version, wouldn't ever touch it again.
To each, his own. I doubt I have ever changed anyones mind on yellow glue, of which I have the same feelings you have of liquid hide glue.
I've made dozens of complicated pieces using both hot and liquid hide glue, and will continue to do so. Liquid hide glue requires tightly fitting joints, because the glue has no gap filling properties, and will in thick sections, remain gummy for quite some time.
Rob Millard
I've been corresponding with Dwain at bearmeadow.com (see link in #7 above). He has given me permission to quote from one of his emails, since he doesn't have time to register, post and keep up with this discussion:
OK, I threw the link in just above. See ya.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
Here is an alternative liquid hide glue.
Patrick Edwards, the maker, does some incredible marquetry with it. This link goes to his page about the glue, take the link to the pages about his work. http://www.wpatrickedwards.com/gluepage.htm
FG is that link still good it does not work for me?
It just worked for me.
It worked for me, try again?forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
jr,
I use hide glue in restoration work, and years ago I worked in a shop that used hot hide glue for nearly all their assembly. We each kept a pot going all the time, and added water and or glue daily as needed. I kinda like the smell (to each his own ). The only shortcoming I've seen with it is the flip side of what everyone says about its creep resistance--It dries brittle, and a less than perfect joint will usually break under a sharp blow. It's normally not a problem to pop a glueblock off an old piece, or open up a glue line just by hitting it a sharp lick. I suspect that this brittleness increases with age, but as Mr Millard has pointed out, we don't know what 200 yr old Elmer's will be like.
It's very convenient to be able to reglue a piece put together with hide glue and to know that what you're using is perfectly compatable with what was there originally.
What is your source for hot hide glue? Do you use a gram strength for common work??
Looking for a new source. I had a 5lb bag but it seems like it has gone bad just sitting dry??
Its time to replenish.
Dan
Dan,
Last couple batches I got from Bjorn Industries (704)-364-1186, it is their #135 Grade, which is what he recommended for furniture repairs. I believe he said it gives a bit longer "open" time for assembly.
Why do you suspect yours has gone bad? Did it get wet? Mine is stored in a zip-lock bag.
Ray,
The higher the gram strength number the stronger the bond is and the less open time it will have.
Do you refrigerate yours or just keep it in the ziploc?
Rob
Rob,
The dry granules I keep at room temp, in the ziplock.
Ray,
As has often been discussed on Knots, some woodworkers talk to their wood. Dan thinks he has been having trouble with his stored hide glue. You asked how he knows he has a problem. I think he should talk to the glue -- try to get a feel for what it wants, and how it can best be used. We tent to treat wood with great respect, but we really tend to shortchange glue. I recommend that Dan spend more time talking to the glue.
Mel,
I've think you may have inadvertently hit upon some true wisdom: Rather than talking to our glue, we need to be sniffing our glue.
Steve,
I have the feeling you have been using solvents without opening your windows.
You're supposed to open the window?
Mel,
Isn't that why high school shop class was so popular? I remember one time when someone thought it would be a good experiment to see how flamable some finishes were.Chris @ flairwoodworks
Chis,
"Isn't that why high school shop class was so popular?"You pay me a great compliment - assuming that I can remember high school. I remember that I went to high school. I remember the teachers were all women dressed in black and white costumes. I remember getting rapped across the knuckles and the back of the head with rulers. I remember a nun we called "Big Al". I remember reading Mad Magazine. But I don't remember Cathedral High School having a shop class. Darn. That would have been interesting --- Learning woodwork from a nun.
Cheers,
For some strange reason I put this granular hide glue from Mohawk(a while back) in a tight container and forgot where I put it. I took it out the other day and soaked it in a small soup can. As usual, I filled the can up about a half inch with crystals and covered it with water or just a little above. Hours later, it was a bit like a round hockey puck-- didn't desolve quiet that much.
I'm just guessing but maybe its too old??
dan
dan,
I dunno. Did you heat it up to see if it went to liquid? I never soak the granules, just cover with water, and put the heat to it. As they used to say at Virginia Craftsman, "that's how we always did it before" (before I ever read that it should be soaked overnite).
Used hide-glue in restoring four chairs about 100 years old. Bought the glue from Lee Valley - - keep it in a sealed container. When you make a batch, put the remainder in a sealed container in the fridge. Easy to make, easy to use and can be "unglued" if things go wrong.
