Hirsh (possibly Hirsch) Frame Clamp Instructions
I have a hirsh picture frame clamp, and need to find instructions/owners manual for it. I have sreached every where in the internet, for it, and can not find the web site for either Hirsh, or Marsh Company.
It has 2 sets of 2 rails, 2 miter corner with a center bolt for tightening.
any help would be Great!
I'm not sure what you need to know, Roger. To use, loosen the center bolt, position the corners to fit your picture frame, they should all be in the same number holes, glue your miters, place the frame in the clamp, tighten the center bolt. You may have to align things in the corners a little by hand before fully tightening. These are excellet picture frame clamps as long as your miters are accurate and the opposing pieces are the same length. The clamping action is basically equal from all directions so it almost forces things to come together correctly without sliding by. You have to make sure the faces of the moldings are flush, yourself. Set it up just like the picture. Clamp on the bench, picture frame on top, good face up.
