My daughter is using a cut sheet of melamine as a desk arrangement. She would like to cut two holes in it for computer and electrical cords.
What should be used to cut the holes (1-2 inches diameter) so that there is no chip-out of the melamine?
Larry,
You could use a forstner bit to drill a clean hole. First, though, drill a perfectly straight small pilot hole all the way through the sheet. Start drilling from one side but go only a short distance -- 1/8" to 1/4" -- then start drilling from the other side. This process will make a clean cut through both sides. I suppose you could substitute a good hole saw for the forstner bit.
Bill Arnold - Custom Woodcrafting
Click Here if you're interested in a good,inexpensive website host.
If you don't have the proper carbide drill bit use carbide pattern router bit. If it chips out drop a plastic wire grommit in the cutout.
DJK
Ditto on the grommet. Even if the hole is clean the exposed particle board core will look like crap and chip over time anyway.John O'Connell - JKO Handcrafted Woodworking
The more things change ...
We trained hard, but it seemed that every time we were beginning to form up into teams, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing; and a wonderful method it can be for creating the illusion of progress while producing confusion, inefficiency, and demoralization.
Petronious Arbiter, 210 BC
I close friend is a plumber and whenever he cuts into fiberglass tubs, showers, or laminates he always uses a hole saw. You make the pilot hole with the leader drill bit on the hole saw with the drill in forward. Then switch the drill to reverse and make your cut with the hole saw. By going in reverse, you make very sallow cuts with each pass and it keeps the saw from being too aggressive and binding on the material. Once you get into the material enough then switch the drill back to forward and continue the cut. Try it on a scrap peice.
I like using a router bit with a jig. Buy the grommet first then size the jig so the grommet fits tight. A hole saw in reverse should work but I would run it in reverse only to score the melamine (this works because in reverse the teeth are pitched down and wont blow out the melamine).
The grommet is definitely the way to go -- then you can cut your hole with either a Forstner or a hole saw, or even a saber saw if the grommet is big enough.
Just be sure to buy your grommet first, so you know what size hole you will need.
Larry
Cut the hole with a hole saw then use a cable cover which cost about a buck, come in a variety of colours & are easy to fit. If your hole ends up a shade too big, glue the cover in with poly or epoxy or fix with silicone.
Just check the largest plug size that is likely to be fed thru the hole before buying the cover. Some earlier printers had a fairly large plug & need an 85mm cable cover.
Don
Many thanks for the tips. She's choosing her grommets and we'll work carefully from there.
Larry, BArnold has the best approach.
I remove the holesaw's pilot drill (1/4")
Drill the pilot hole as BA suggests
with a regular 1/4" bit
Then I substitute a similar length of
1/4" drill rod for the holesaw's bit
as that bit will wander and create
an egg shaped pilot hole.
After drilling the pilot hole and to insure
against 'chip out' stick a patch of wide
masking tape over the area
Also, drill down from the top 1/3rd of the way ,
then from the bottom up 1/3rd.
Finally,finish down from the top.
Save those plugs They help guide your drill
when you dont have a drillpress to drill
a straight vertical hole. Stein.
Edited 1/12/2005 11:08 pm ET by steinmetz
