Merry Christmas to all!
I have a question for my first post on this forum. I recieved a set of high quality chisels for Christmas, and I need some advice on a mallet, (instead of using a steel hammer as I did with my cheap ones) Mostly I will be doing dovetails and cleaning up mortises with my chisels.
I read somewhere that holly was a good wood for a mallet. I have a chunk of holly that I salvaged from the roadside and has been drying in my shop for 18 months. Any experience with this?
I have seen round and square headed mallets. What is the advantage to a round head? It looks akward, but then I havent tried one.
Round headed mallets are typically thought of as carver's mallets, to be used to drive carving tools with precision. The advantage of a round head is that every side is the face, i.e., there is no need to spare even a glance to ensure the mallet is lined up and ready to strike properly as might be necessary with a square head flat-faced mallet.
While round heads are usually thought of as for lighter work with carving tools, etc., larger round ones work perfectly fine for most any chisel driving task, including mortising and dovetails. It's largely a matter of personal preference.
Square head mallets are typically thought of as carpenter's and cabinetmakers' mallets. A choked up grip on a 25 ounce (3 1/2 x 4 x 5 1/2 roughly) hard wood head is the preferred method for mortising and the other heavier chopping duties. Again, I personally think it's a matter of what you like and are used to.
Edited 12/25/2006 9:34 am ET by Samson
"The advantage of a round head is that every side is the face, i.e., there is no need to spare even a glance to ensure the mallet is lined up and ready to strike properly as might be necessary with a square head flat-faced mallet."
And because of this, I find a round mallet far less taxing to use because I can relax my grip on the handle during the up-swing; with a flat headed mallet my wrists, forearms, and hands fatigue more unless the shape of the handle enables me to maintain the correct orientation without looking (which enables me to relax my grip on the up-swing).
Some may think I'm over-cautious, but I wear hearing protection whenever I use a hammer or mallet because the transients produced by hammer blows are loud enough to cause permanent hearing damage.
My favorite mallet has a head made of lignum vitae.-Jazzdogg-
Merry Christmas sflund, Holly turns very well, it takes details good and its a bit soft for heavy mallet work. I would find another way to enjoy the Holly. You will love the way it turns.
Cheers
hello the round headed mallet is mainly used by carvers or in the joinerers shop for light driving of hand tools, the larger square headed mallet will be used more for assembling doors etc . The normal two flat faces will take some dents etc from chisel heads ( morticing etc ) so the sides which are usualy slightly barrelled are used for assembly work without leaving dents and bruising to the work.
suggest square first round second. turn a nice round lidded box from the holly.
regards Teabag
"the larger square headed mallet will be used more for assembling doors"
I understand your preference completely. It's always interesting to see the tools and processes different people use to tackle the same task. I usually use a so-called Dead-Blow mallet and a rubber mallet for assembly, round mallets for carving and light joinery, and Square-headed mallets more for large-scale joinery , timber framing, etc.
-Jazzdogg-
Thanks for your responses. Maybe a chess set from the holly? (with some purchased ebony)
Steve
