Anybody have plans or ideas for home-made spoke shaves?
John
John
I seem to remember on the TV show "Woodwright Shop" or something like that, he made several. Check out his books, the might have some information!
I think there are plans included with the blade you can buy from Ron Hock. A friend of mine made one and it was very nice.
Troy
Pins,
The following is a good site to get you started. From there you can make different ones to suit the task at hand.
http://www.shavings.net/TEACHSHAVE.HTM
Good luck,
Tom
Thanks to all. I think I have enough to get started.John
Pins,
Lee Valley sell a basic kit or two (blade and adjusters - the metal bits) for you to make your own handles and so forth. I think they include some form of plan.
But perhaps you are wanting to make every part of the shave yourself, in which case the Lee Valley kit would not be right for you.
Lataxe,Yeah, I saw it and I think its a good option. I generally like the stuff they make. But I didn't like the rear ball handle they made for their low angle block plane, but the plane is nice.ThanksJohn
I have used the Lee Valley kit to make a low angle spokeshave.
It performs VERY well, and the blade adjustment works great.
You can achieve a very fine mouth with this kit.
Check out the photos.
My only gripe was that the countersink cut the threads for the adjuster
a little large, so there was some slop and I had to put a little paper in there
to get a tight fit. I tried threading a few scrap boards to make sure it wasn't
bad tapping skills on my part, but i had the same issue each time.
Don't let that discourage you from this kit... it was a joy to assemble
and the shims solved my problem easily. The blade is A-2 and holds a
good edge. I would give it an 'A-'
If you are trying to build a normal angle shave, I don't know of any plans for those.
I would look at HNT gordon's wooden shave and an example. Also, you could
look at Japanese spokeshaves- they're all wood as well.
Nice shave, thanks for the tip. Did you ask LV about the machining problem? They're good about fixing things.John
