Hi Folks,
I’m trying to sort thru all the info. on the WEB about constructing a vacuum press and, well quite frankly I’m boggled!
I have an old waterbed mattress and a compressor from an old refrigerator that I would like to use to make a vacuum veneer press. Can anyone tel me what parts I need? What I want is to make a simple system and after perusing Joe Woodworkers WEBsite I have decided on a continuous system.
Can I simply connect the compressor to the bag, clamp it securely and proceed to veneer heaven!? I’m sure it’s not all that simple……….
So far I’ve determined that I need a connector for the bag, some tubing to run from the bag to the compressor and I have identified the vacuum – side of the compressor as opposed to the + side and have pinched off the freon tube.
Sorry if this isn’t much info. but if it’s any consolation I’m eager to learn. 🙂
Given the above how would you go about constructing a press?
Be aware that refrigeration pumps were closed systems and got their lubrication from the refrigerant, running them open means they will be unlubricated unless you add lube.
Also the lubricant used in refrigerants was usually alkylbenzene which is not healthy to inhale when misted as would be the case at the output side of your pump. You might consider venting the output outside.
The waterbed mattress works great, I use that method myself.
Giving money and power to government is like giving whiskey and car keys to teenage boys.
-- P.J. O'Rourke
Don,
Thanks, I'll check into the lubricant part. Right now it's pinched off so nothing in-out.
Also, I would like to adapt the fill hole for the adapter to connect the pump. Any thoughts on this?
For clamping the bag would you recommend this?
http://www.veneersupplies.com/product_info.php?cPath=60_67&products_id=3484
They look like they could be made from som ePVC pipe but the price seems right.
Edited 6/23/2008 3:04 pm ET by KiddervilleAcres
Bob, You've found the right place! Joe lives about 15 miles from me and is a great guy. Everything you need for a press can be found on his site. Go to his other site, http://www.joewoodworker.com , and you'll find all kinds of information on building the press, etc.
Veneering is addictive!
Dick, an addict
I built the Joe Woodworker system and used his bag and closure. It works, it is not really expensive, and you will save all the hassle of trying to make a pump work to do something it was never designed to do. I like to save money any time I can, but I decided that Joe's system was the right tool for my use. Check it out a little more and you may save a lot of frustration. Good luck!!
Bruce
Bruce & Dick,
Thanks for your encouragement and I look forward to the adventure. I too am frugal with my woodworking dollars and so I want to try vacuum press veneering with a small investment.
My frugality may lead to wrong conclusions on my part but I look upon this as a way to gain experience.
My Uncle has a stash of some really nice curly maple that I would like to stretch. Hey, maybe I've found the proverbial board stretcher!
If you watch David Marks on TV he is a proponent of using shop cut veneer to make a board stretch. Using the right techniques, one board can really cover a lot of area. His work is superb and there can be no complaint about using veneer to create a really eye popping project. Good luck with your efforts!!
Bruce"A man's got to know his limitations." Dirty Harry Calahan
Bob,
As far as a bag closure, fold over the end of the bag a few times and clamp it between a couple of boards. Not glamorous, but to test your system and get started, it works. Or fold it over and roll it around a piece of pipe or a dowel. A few spring clamps and you are in business. The $13 closure is great if you are ordering other supplies as well. If not, the price will likely double or more with shipping.
Test out your system first. The lubrication issue is critical, so depending on your pump design, you may end up going another route.
I chose a venturi system. I didn't have shop air, so for the price of a good vacuum pump, I got an air compressor and a venturi vacuum system.
Greg
Exo 35:30-35
