I’m trying to find a bit that can make the profile on this bead board. I had it made for a project in the past. The guy made it with a W&H molder. I cant afford that right now, so I’m looking to replicate on a router table. Problem is I can find a beading bit with that chamfer or as it was called on the W&H catalog V bead. I’ve looked at my usual whiteside and freud and just can’t seem to find a bit that could cut that profile the bead + the V. Anybody out there got a suggestion.
I was married by a judge – I should have asked for a jury.
George Burns
I have made it with a Sears type molding head that goes on the TS .
sort of a scary tool but most router bits won't reach the cut you need.
regards dusty
I have a cutter head that I got from Sears decades ago that has three cutters that takes interchangeable blades. Closest thing I could find by googling was the Magic Molder. Same principle with two cutters instead of three.
http://www.holbren.com/magic-molder/
Maybe I'm being unusually thick, being Saturday night, but I don't see how it would be possible to do that cut with one router bit -- the router bit rotates across the profile. It might be possible with two -- a plunge roundover bit to make the bead, then a chamfer bit to finish off the vee edge? Still tricky, though.
Jim
bones,
I also have the Sears Molding Head set. I'd be happy to loan it to you if you would like to use it. It doesn't have all the profiles and I believe there were additional cutters/profiles available. It's been used maybe 5 times.
Email me if you're interested.
How much do you need? In my house that stuff is full 1 X 4, I made a few pieces like that by hand with a Lie-Nielson molding scraper.
As others have said .I use a Sears head on the tablesaw.Feed slowly with a feather board pressing down.Another suggestion is an old wooden moulding plane and a clamped straight edge for a guide for short runs.Thirdly you may be able to purchase it from a lumber yard as it is a common profile
bones,
After thinking more about the Sears set , maybe there was a triple bead and we did a re grind to leave the single bead , but I have made backs and door panels for several jobs with this tool and it works fine .
I have also made knives to make T & G beaded board on the shaper it took like 3 or more passes without a molder .Had to run the bead detail with board on edge but flat for the rest.
I ran about a thousand lf feet for a curved wall in a wine cellar at different widths so it could make the radius of the wall , There was room for the tongue to bend in the groove .
regards dusty
Bones,
The simplest solution is not to make the "false" bead in the middle at all. Use narrower stock and make a conventional bead profile at each edge with your router. After all, the profile that you're copying is "faking" that construct anyway.
David Ring
http://www.touchwood.co.il/?lang=e&id=1
Wow, thanks for all the replies. I've looked at TS molder heads and just don't think that's a direction I want to go. If I were going to do that, the magic molder would be a real solution. They even had the knife set to cut the pattern I wanted. The cost of the system and the knives put it a bit high as I would want to add a power feed to get a good consistent cut. Using a TS set gives me the same feeling I get when I use to use the RAS. Ring has a real possible solution that I looked at as well. Amana had this Bit for making a the 2" narrow strips with a bead on the end, but its a strait bead without the "V". I may have to either just suck it up and do the strait bead without the "v" or continue to look and save for a used W&H or woodmaster molder on E-bay or craigslist. I had hoped that there was a bit out there with similar construction to the amana bit with the "V" on it. Thanks again for all the input. I was married by a judge - I should have asked for a jury.George Burns
How about a couple of molding planes? I have used a 3/16" beading plane on 1/2" tongue and groove board (which I cut with a tongue and groove set). The center bead can be cut with a centerbead plane. Depends on how much wood you want to cut. I made about 18 feet complete in about 30 minutes. I just got a double bead (3/16") which allows me to not worry about the grain directon on the stock, a real advantage.
