My 12″ cms is about a degree out of alignment. Anyone know how to square it back up? Thanks in advance.
Call Delta, they will help you out.
Good luck
I've got an older Delta CMS (the model nbr escapes me at the moment). I loosen the fence bolts, lock the blade straight out at the zero setting, and put a good square up against the blade (the plate, not any of the teeth) and adjust the fence until it contacts the square. Then re-tighten the fence bolts to lock it in place.
Waddaya mean it wont fit through the door?
