I have an Adirondack chair project in progress, and I bought all the lumber in clear western red cedar. My problem is that the seat bottom and back slats were designed as full 3/4″ thick “1x” lumber. What I got, and I paid a fortune for it, is 5/8″ thick, a full 16% thinner. To use this stuff I will need to modify the design, adding an eighth here or subtracting it there, but I am bummed that the slats will deflect more under load and the overall look, since the back slats are such a key feature, will be lessened with the thinner boards. Is this 5/8″ thickness what all the mills are shipping now? I am in the northeast, and probably all that comes in is from the Canadian west. I cut and finished all the parts made from 1-1/2″ and 5/4 stock, but have not touched these so-called 1x boards yet.
Any of the 4/4 wrc that I have used in recent years has been scant. You can get an sis2e wrc , but even that is a problem because it's 13/16ths thick and rough on one face, so getting a full 3/4" is next to impossible. If you can find it full sawn (rough) you might be able to make it work, otherwise you will probably have to use 5/4 and mill it down.wb
If you go to Home Depot or Lowe's you can get 3/4" cedar. It is normally used in decking and comes in 10 to 12 foot long.
