Hey all,
I was recently given a block of briar with holes already drilled for a pipe. The block has been left for me to carve. I have no idea where to begin. I’ve read some articles that say briar chips when you use a carving knife. Can anyone confirm this? I’d appreciate any advice from people who have experience with this type of project. Also any websites that might have some useful information would be greatly appreciated. Thanks!
Try Googling carving a pipe from briar; got lots of hits like this one: http://www.woodcarvingillustrated.com/forum/f61/briar-pipe-7416/
FWW issue #20 pages 82-83 (March 1980) from the days before the publications “furniture obsession”.
Along with cigarettes I smoked a pipe for many years; when I was in high school I carved several from oak tree branches. Occasionally I would modify some of the briar pipes that I owned as well. Briar is very hard and fine-grained; I found it similar to cutting end-grain on seasoned oak or hickory. You will require an extremely sharp knife and even then, you will be able to take only light cuts or chips. I found it easiest to work with rasps and files - a shoemakers 4 in 1 worked well for me. I would shape it with the rasp and then come back and smooth it with a knife - or sometimes vice versa. You might try the trick that carvers use when cutting end-grain: moisten the surface a little bit to slightly soften the wood. I didn't have any trouble with chipping, but if your piece is burled, you might have that problem.
I have a pdf of an old Mechanix Illustrated article about turning a pipe on a lathe. I'm not sure exactly where I found it online, but I think it was at the Internet Archive under woodworking or some such. I'll see if I can find it again and post a link for you.
I found the link to the old pipe-making magazine article. Here it is:
http://www.vintageprojects.com/woodshop/pipe-making.pdf
It has to do with turning a pipe on a lathe, but it is interesting nevertheless.
Hello again. I forgot to mention that the link is to a pdf. You will need Adobe Reader or something to open it.
Thanks for the input everyone. I thought I'd post the finished product.
Hey, that's pretty nice. Has anyone tried it out yet?
Good work.
As a sometime pipe smoker I can say that the bowl shape is critical. Something like a tulip but not so enclosed
nicely done.....good looking pipe.
