picture this –
I am making a mitered box lid with a veneered top (babinga burl) inset into a slot cut around the inside perimeter of the mitered frame. I have the veneer laminated to a 1/4 inch plywood substrate. I need to cut a rabet (through the burl and into the plywood) to fit into a dado in the mitered frame. If it was hardwood I would just put it on the router table and route away. But I am afraid it will make a mess out of the veneer. How do I cut the rabet?
I was thinking of cutting through the veneer with a razor so that when I route out the rabet, the veneer has already been cut and won’t chip away.
Better way?
Can you make the groove wide enough to accept the full panel or rabbet the back/inside face instead? That would protect the edges of your veneer inside the groove forever. If not your razor idea is a sound approach.
I cut the veneer with a marking gauge before I make any cuts, dados, or rabbets. It only takes a few seconds and saves you the frustration of fixing a chipped veneer.
Marking gauge is a great idea. Easier to cut a straight line than with a razor.
A few swipes with a marking gauge, then on to the table saw or router. Worked beautifully!
