Peter: A friend gave me an antique china cabinet with curved glass in the side panels and the door. She was a heavy cigarette smoker and the cabinet smells like a chimney for a cigarette. What can I use to get the smoke smell out of the wood on this cabinet? Thanks for your help.
Root,
I think the best thing to do is to put it in a location so it can air out for a while. It may take some time but will eventually dissipate.
You could also wax it with Black Bison wax by Liberon. This product has a fairly heavy"perfume" to it. For what it's worth, many people buy it for the fragrance. For me it's a bit heavy but is a good wax.
I know that's just trading one smell for another. You could also lightly wash the surface with a little dish detergent and water. The operative word here is"light" I would dampen some paper towels with it wipe the surface in sections and dry right behind it. Do this a few times and it might be a great help. It's one of those Keep It Simple methods that works quite well.
Peter
Thanks for your help. I thought about "wipping" it lightly with a mix of 1lb shellac, as that should seal in the smell. What would you think of that? Thanks in advance for your thoughts.
root,
Before you pad any shellac on the surface be sure it's clean. No sense locking in dirt too.
A couple of ways you can have a little fun with shellac;
Put a drop or two of vanilla extract in your shellac.
Another is to add an alcohol soluble resin, gum benzoin, to it. It also will impart a mild aroma of vanilla. It can be found at Kremer Pigments in New York city. There are also tinctures of benzoin available at pharmacies.
Have fun.
Peter
If you have access to an ozone generating air purifier, these will do the trick. I purchased one for our home after trying it out. It leaves a room smelling like the air after a refreshing rainstorm. The lady I bought mine from discovered them when her mom had a fire inside her home leaving everything smelling like smoke. It took the smell out of the draperies, sofa, furniture-everything. Somehow, the ozone reacts with the "odor molecules" and destroys them (not too scientific of an explanation).
They are pricey. I think I paid $400 for mine a few years ago. The lady I bought mine from is still a dealer. If you are interested, message me and I will put you in touch with her. She was much lower than the other retail outlets.
Also, I had a gallon of milk leak into my car carpet on the way home from Wal-Mart. A detail shop loaned me one of these industrial units and the dairy smell was gone after running one overnight. You may be able to borrow/rent one from one of these shops, or from a company that clean up after a fire (ServePro, etc).
Anything that you put over the wood will trap the odors underneath. There is probably a heavy coating of tar/nicotine on the wood as well. A thorough cleaning would probably give life back to the finish.
Here's the link to the company who makes mine (I have the Flair).
http://www.alpineairproducts.com
Exo 35:30-35
I had the same problem with a dining room hutch that belonged to my wife's grandmother.
The smoky smell was on the unfinished wood on the inside of the cabinet. I believe it would be difficult for the smoke to penetrate a sealer such as lacquer or varnish. To resolve this problem I first washed the entire cabinet with Murphy's Oil Soap. After allowing it to dry I sprayed a light dusting of Liquid Gold and then rubbed it in. This did the trick very nicely.
ve
