Hi All
I have an old wooden salad bowl 17″ in diamater, 5 1/2 ” deep that has been sadly neglected.
I think it is oak or walnut
I plan to build a dry sink and use the bowl for a sink by instaling a drain in the bottom.
Would I use a peanut oil and bees wax finish or a rubbed spar varnish finish , or something else??
Also, what is the best way ( other than hand sanding ) to get rid of the black oxidization the bowl has accumelated??
Stewie
The Sawdust Shop
Just how old is this bowl ? Antique? Drain denotes that you may be making it a Wet sink ? You might be on a road of destruction to a valuable bowl. I suggest save the bowl and get a hammered copper bowl. IMHO
Bruce S.
The bowl could be 40 years old , or older.... How do I find it's value??? I have had second thoughts...stewie
The Sawdust Shop
40 years isn't terribly old, although the age of bowls can be hard to judge. The style, species and size can all play a role in how valuable a bowl is. And sometimes seemingly poor condition can mask a bowl's true value. I've got a Redwood Burl bowl that I picked up at a Good Will store for $1.25 about 10 years ago. It looked like somebody's High School woodshop project, but I cleaned it up, refinished it and I'm pretty sure that I could get $200 or more out of it if I were to put it in a gallery that deals in wooden bowls.
Could you take some pictures of your bowl and post them here? I bet that between us we could give you a good idea of it's value based on the pics.
Picture is coming. "Always a new way to screw up"Stewie
The Sawdust Shop
Value is in the eye of the beholder. All pieces of Americana have some value, even it only sentimental. " Grandma's or Great Grandma's " bowl is worth saving intact and its story and history passed on for generations. I am still using my GGG Grandmothers Chestnut dining room table which traveled by covered wagon from Harrisburg Pa. to Salem OH. And my Grandchildren love the story.Work Safe, Count to 10 when your done for the day !!
Bruce S.
Thank you Bruce. I think I'll clean it up and re-finish it , then my kids and grandchildren can have it. I'll tell them it almost became a sink :)."Always a new way to screw up"Stewie
The Sawdust Shop
Forty years old (or even 80) won't be a terribly valuable piece. BUT installing a drain is not an avenue to a "dry sink". It cannot be protected adequately from water to use as a sink, in my opinion. It will split.
As for "black oxidation", it sounds like it has already been in contact with enough water to damage the wood and will need to be bleached.
Please tell us more about the use of this piece. I am not getting the picture.
Edited 7/7/2007 9:26 am ET by Gretchen
Hi Gretchen My mother is 94 and the bowl was hers. I don't know if she bought it or if it belonged to my grandmother first.There are no name or dates on it. Unfortunately we have let it sit in the basement for years with very periodic use. I don't think it has been re-oiled for many years. There is a 1 1/2 inch crack along the rim that you can see thru and another on the opposite side , about 1" that is tighter.The color is a medium brown to some black along the rim. So we can see lots of grain. My idea was to build a dry sink for the loft bathroom , and then cut a hole in thetop and plumb in a sink. I had thought the bowl would make an interesting sink.If I can restore the natural wood color to the bowl , I now think I'll find a better use for it. ( We don't make many large salads )."Always a new way to screw up"Stewie
The Sawdust Shop
I'lll say again, you really can't use a wooden salad bowl for a sink. It is already cracking. Bowls this size have some value, even if "only" 50 years old. The black along the rim probably needs sanding. You can wipe it out well with mineral spirits to clean it. And you could give the inside a light sanding but that will remove the oxidation that is giving you the nice brown color
Use it on your counter for your fruit and vegetables.Gretchen
