how to make 2 degree bevel on a vise jaw
I’m reading the instructions to fit my shiny new vises and it mentions “to ensure correct jaw operation we recommend beveling the front jaw to 2 degrees..” I can’t think of a great way to do this other than placing a wedge/ strip on the opposite side as it goes through the planer. Could someone enlighten me? I’m stuck and know there must be a good way to sort this out.
You could just cut a 2 degree angle on your table saw, then flat joint it smooth and you'd have it.
Thanks Hal, the thing is the jaw is nearly 6" tall so I'd have to flip it, but I guess it would work out after jointing.
Or if that seems a little scary on the table saw, go back to the stick as a shim under one side of the board on your planer. Whenever I do anything like this I always use double stick carpet tape to attach the shim so it doesn't slip out of position.
Hal
http://www.rivercitywoodworks.com
NumberNine,
And if your stock is not held square in the vise while edge jointing...what then?
BG,Typically, there's enough "rack" in the vise to end up holding the piece square, which is why you normally but a bevel on a jaw face.
How about a hand plane?
adam
Adam,
Now that's crazy enough, it just might work!
If you have a bandsaw, tilt the table 2 degrees and nip off a wedge, tapering from 3/16" to zero. Clean up the cut on your jointer or with a hand plane.
Ed
Another way to approach it is to try using a washer or two between the vise mounting holes on the back side of the vise and the bottom of your bench. If you have to choose between leaving out a washer and having an angle greater than two degrees, go with the extra washer. This will ensure that the racking works to your advantage when you apply that extra bit of OOMPF. It worked like a charm for me. This technique requires that you have the front mounting screws tight.
There was also an article in FWW on this topic by Tom Begnal.
Best of luck,
-Tom
