Need to refinish a 15 year old deck that wasn’t properly maintained. The deck currently has a worned redwood solid color stain over regular lumber (not redwood, I was told). Went to HD and one rep. showed me their BEHR’s DECKplus solid color stain. Before rolling it on, they recommend that BEHR’s #64 15 minute Quik-Fix deck finish remover & wood resurface be use to remove the old finish. Any and all advise on how to proceed is appreicated. BTW, how can the color of deck railing be change from current redwood color to white? White Latex color paint over the redwood stain?
I used Thompson's Water Seal Translucent Stain on our deck that, like yours, had not been properly maintaned before I got to it. I didn't strip off the previous finish and didn't notice any problems at all in that. It was a different color and turned out as advertised.
I haven't tried brands other than Thompson's, and my understanding is that Thompson's is an under-performer. That being said, I've also used Thompson's on untreated lumber (regular old 2x4s) that have been exposed to weather for 3 years and they're showing no signs of deterioration.
The process is easy to describe, and maybe to do.
First, remove and replace any soft or rotted decking. Then clean the deck. Lots of products are available -- pick one and do it (I've not used the Behr that you mention, but it is probably as good as many others). Don't use a pressure washer, because it will damage the wood. When the cleaning is done, you will (hopefully) have a deck that looks much like a new one.
Let all that dry out for a few days. That gives you some time to decide on what stain to use. For decking, use a translucent stain. I prefer the ones that are linseed-oil-based, because they are really good for the wood. But lots of decks out there have lots of water-based stuff on them too.
As for the railings -- a white opaque stain will do the trick.
August 2003 issue of Consumer Reports gives a report on the long-term testing of deck stains. Check at your local library.
In terms of pressure washing--I did it on the cheap and used a garden hose, a scrub brush, and a bucket of water with Dawn dish detergent.
