I have a Delta 14′ bandsaw that has developed a loud “screech” every time it’s turn on. I’ve checked everywhere for any type of rubber that could cause the sound. Through process of elimination, found that I need a new wheel bearing for the upper wheel. The problem is how to get the old one out of the wheel hub where it seems to be somewhat frozen. I’m afraid the do much pounding on it for fear of damaging the wheel. Is there any knack to getting these out or should I just take it to a service center?
Most auto parts stores have a tool loan program. I'm sure they can fix you up with any kind of bearing puller you need.
I believe you need a bearing press of some sort. I had a friend in the auto business that referred me to a place with a press. It is not as complicated as it sounds just need the right tool/ So I would call your auto mechanic see if he or she could do it. If they could not do it then ask them where you could. I needed to replace the wheel on an old badsaw and the replacement wheel was thicker in diamter than the old one so I could not replace the retaining ring. I asked around and found a place that could machine a small grove in the axle that I could put the ratainging ring on. Point of the story, just ask around a lot.
Kenney66
You should probably take it to a service center. It's really quite easy if you know what you are doing. As a service tech I just use a piece of tubing that fits the outer race on the bearing and tap it out. The main part of the wheel must be supported on some blocks of wood. Bandwheels aren't a pressfit requiring a specialized press. The same process in reverse to put it back in. You might try a local garage and they might let you watch so you can see how it's done.
just did mine, used a piece of doweling on the bearing, loosened it first with some isopropyl alcohol( not sure if that is the right spelling ) it seemed to cut through the gunk though. dan ah spell check
If you decide to drive that bearing out be sure to support the wheel at the hub, not the spokes or the rim.
