I just recently discovered that our 48″ round oak dining room table is a Charles Limbert. The finish is quite worn on the ends and no longer matches the leaves (3 of them). The question I have, which method should be used to restore the finish of the ends to the leaves, and not damage the “value” of the table. Or have I watched too much Antiques Roadshow episodes where the restoration caused more damage then the wear and tear. Table has been in the family from at least 1920’s. Matching Hutch is in Idaho with a cousin who will not give back, the matching chairs, 6 in all, sold off by a step father who thought they were uncomfortable, I could dig Earl up for that one.. I was going to strip the whole thing, till I discovered the maker. I don’t want to destroy the value. One gentleman suggested just throw a table cloth over the whole thing rather then try to match ends and leaves.
Thank you for your time,
Oswego, NY
suggestions
You might want to talk to a good antique appraiser first, to get a handle on the potential value of the table. Then, if the value warrants, talk to an antique restorer - someone with creds in the antique market.
Limbert table
Ralph, I agree with you. The table has been in the family for close to 100 years, spending a few days researching its value and the correct way to restore is definitly worth my time and effort.
Thank you for suggestions
lines
I'm a "Road Show" junkie, too. All those examples of refinishing ruining the value of rare antiques have sunk in. "Refinished as it has been, it's worth about $200. With the original finish it would be valued at about $200 gazillion at auction." "Oh, [bleep]."
There is, however, a line between functionality and auction value, I suppose. Where that line is, value-wise, probably varies on an individual basis.
Lines
I can't argue with your logic, as long as I stay true the Mission Oak style on the refinish (via Jeff Jewitt's refinishing guide), and don't put 20 layers of varnish or poly on it, I should be all right. It's not a museum piece; it’s a table that has had thousands of meals, ashtrays (thanks Mom), and papers stacked on it. When its refinished, I will post before and after's. Thank you for your replies and council.
