I’m building some display cases for guitars. They’ll be 1′ deep, 2′ wide and 4′ high. I want to incorporate a humidifier to keep the inside of the cabinet around 40% RH. Any ideas?
Humidor humidifiers? - Available in several woodworking cat's.
jdg
ChuckT
I've had the same project on my list for a while. Did you design it yourself, or did you find a plan you liked somewhere?
Stan
I designed it myself. It's a pretty simple frame and panel design with glass for the panels, so bothe the front and sides can be seen. It's not fancy, but I'll send you a copy if you'd like. It's big enough to hold a jumbo 12 string.....
Have you considered contacting a guitar retailer to ask what they use?
If you can get a hold of someone at Taylor or Gibson, they might be able to tell you.
Or call the owner of a store in Minneapolis called "The Podium". Their number is 612-331-8893, according to their card that i have that is a few years old.
They specialize in acoustic instruments, and would know what would be appropriate.
(And let me know what you find out, that's a good idea, I might do that for my Taylor.
Try http://www.vigilantinc.com I'm not sure what humidity range you are looking for, but that have cabinet humidifcation devices typically used for cigars. Website says it maintains at 66-74%
Hey ChuckT,
How about using a soundhole humidifier just as you would in a guitar case. There are several kinds on the market. It would be more effective inside the guitar because the outside has a finish.
Enjoy, Roy
Humidifier
Hey it's been a long while since your post.did you ever find an answer to your problem.im going to build one for the wall.i live in mass and the winters are really messing with my gibson songwriter. I'm going to try mold resistant spong with water in plastic container and two electric meters I will mess with size of containers till I get it rite .im also going going to put a p c fan in it if needed for ventilation lights two I've read if you want to lower humidity lights will help.also a cheep thermostat .with wood and plexi doors project should cost between $150.00 - 200.00 let me know how you made out.
thank you
wayne
Humidifier
If any of you guys finishes this humidor please add pictures. Thank you
