I just finished spraying a piece of maple with 3 coats of lacquer over 1 coat of sanding sealer. Nothing I haven’t done before but for whatever reason the surface feels like 100 grit sandpaper. I’m ready to sand it and put on another coat but I have no clue what caused this and I’m not sure what to do to avoid a repeat.
Does anyone have any advice to offer on this?
When spraying the coats with an HVLP sprayer everything seemed like it was going on just fine.
Thinned lacquer with lacquer thinner 25%
Sprayed at 20 psi
Thank You
Since you say you've done this before I'm going to assume you put your coats on wet enough, but since you are asking the question it doesn't seem like you are a pro so don't rule that simple solution out.
Assuming you did put on wet enough coats, that leaves the old nemesis of spraying finishes, temperature and humidity. Unless you are fortunate enough to have a carefully climate controlled shop, you are always at the mercy of the weather. It sounds like your lacquer was drying before it had time to flow out into a smooth finish. The solution to this is to use a retarder to slow the drying process, but be warned if you use too much retarder you can find your project covered in runs and sags since it will affect the drying time making you more vulnerable to such things.
Thank You esch5995
I'm sure I put it on wet enough but I was in the direct sun and it was around 95 degrees so maybe it was drying too quickly. I think I'll run some 320 over it this morning and get another coat on while in the shade.
In the sun? Why did you do that?
An edited comment doesn't bring a thread back to the top page?
I don't think so. I've been adding the task of going through a few extra pages to look for links to my morning routine.
Oh boy, a fun way to start the day.
Been there........have the tee shirt.
The lacquer droplets on the outside of the cone of spray are drying before they reach the surface. The dried particles sticking to the surface are what you feel. Sometimes they appear white.
The solution is thinning with lacquer retarder rather than lacquer thinner. This evaporates slower and eliminates the problem. The only issue is that some of the retarders don't smell great and it takes several days for it to dissipate. I leave the work sitting in the hot garage to air out, and the wife complains about that.
20 PSI sounds really low for a HVLP gun.
The gun I use works best on 10-12 psi. Too much air leaves a cratered or orange peel surface. Definitely don’t spray in the sun.
SPAM SPAM SPAM
Uggg!!! These spammers are getting trickier. They have been going back and editing their comments and adding the spam in. I mulled that one over for too long yesterday, debating if it was spam or not. The answer seemed legit... boom now a link was added!
Interesting. I wouldn't have thought of editing the spam in, after the fact.
