I often see the “spec” of 10 psi at the tip of an HVLP gun. Is this a guess or is there a way to measure the pressure AT the tip?
Considering building my own system–got a great deal on a 7.2″ 3 stage motor and dying to make something of it.
<=10 PSI is the government mandate which must be met to call it HVLP.
Mfgs. sell special nozzles that have a gauge attached to measure tip pressure.
Meaning to qualify as HVLP there can be no more than 10 psi at the tip?
yes
Hmmmm.... a qualified yes.
The gun has to be capable of 10 PSI at the tip to meet the government's definition of HVLP. That doesn't mean that the gun can't be capable of more than 10 PSI at the tip, though. Nothing changes with 11 PSI at the tip of an HVLP gun other than the fact that it doesn't then meet the EPA definition of "HVLP." Another way to state that would be to say that a non-HVLP gravity gun (for example) spraying 10 PSI (or 11 PSI) at the tip is not going to behave the same as a conversion HVLP gravity gun spraying at the same exact tip PSI. The conversion HVLP gravity gun will atomize the same paint better @ 11 PSI at the tip than the non-HVLP gravity gun will.
Kevin
Many times I have posted plans for a dual motor turbine HVLP unit that will provide 10psi at the gun. The 3 stage motor will produce 5-6 psi. The 7.2" motor coupled in air series with a $50 2 stage will provide the 10 psi. A router speed control can be used to control the air volume or psi. I pitched this plan as an article to FWW but they turned it down saying it's not right for the magazine.
Dave Koury
Dave,
I've seen your posts and even have some pix saved for future reference. One thing I don't understand is how a very expensive 7.5" 3-stage motor can underperform (less than 10 psi) the cheaper 5.2" 1- and 2-stage units found in many systems. Is there more here than meets the eye? Efficiency of the enclosure? Hose size, type, connectors, filters, etc...?
I would be most grateful if you could extend a copy of your plans for a HVLP system. I am thinking of building one. Thank you
Ng Chee beng
