Hello Everyone,
I’m thinking of treating myself to an early christmas present! I’m in the process of building a walk-in closet and don’t really have any desire to finish it by hand. So, I’m thinking of buying an HVLP sprayer.
Unfortunately, I know very little about them. Can anyone help me out with the following questions:
– what brands/models are the best
– what can I expect to pay for a good one
– what types of finishes can they be used with (specifically, do they work well with shellac?)
– any specific problems you’ve had that I should look out for
– If anyone’s from the Toronto area, any good places to buy them
As usual, your help is greatly appreciated!
Dan
I have a Fuji Q4 and I like it a lot. You can find good systems for around $500. I tried a couple of lower cost units and they sucked. Accuspray and turbinaire are also very popular. I think that the Fuji turbine is probably the best, but the gun's machining was not as good as I hoped for, though it sprays great.
MIke
have a accuspray conversion gun (powered by a compressor) and love it http://www.compliantspraysystems.com also check out this place http://www.homesteadfinishing.com you cant go wrong with products from either site
Darkworksite4:
Estamos ganando detrás el estado de Calif. Derrotando a un #### a la vez. DESEA VIVO LA REVOLUCIÓN
You might want to take a look at the current discussion under Tools for Woodworking titled "Good HVLP setup". It covers quite a bit of your question.
Michael R.
The Wagner Conversion HVLP spray gun is a good choice as an entry level gun. Costs around $130, works with a small compressor, and sprays well (including shellac).
If your spraying needs outgrow the cup gun in time, you can move up to a more versatile system like a 2 quart pot and keep the cup gun for smaller jobs.
Paul
The most importaint thing is what you will be spraying. To spray latex and oil finish paints is a lot different than spraying a light varnish.
So is their a sprayer that works well for both painting and varnish/shellac type finishes?
I seriously hope your're not planning to spray shellac in a confined space like your walk-in closet. It's probably only second to lacquer in volatility. We's hate to lose you brother.
I have the Wagner mentioned by in a previous reply, and it does well with everything from thick latex, to thinned oil-based stains.
NOTE: This might be the most important thing mentioned in this forum in the past 6 weeks. Shellac is based on denatured alcohol. Denatured alcohol has a flash point that is very near to normal body temperature (I think it might actually be 96 degrees.) That means that if the air-fuel mix is right, and you breath in the same room, YOU WILL IGNITE the explosive mix.
And as the previous poster mentioned, we really don't like losing our Knot-headed brethren.
Vast projects should not be founded on half vast ideas.
Very good point and thanks for the heads up. I have a large window in the closet and it will be opened at all times. Since I'm up here in Canada, I don't expect the temp to get anywhere close to 96 (although it would nice).
Dan
I own a Graco Procomp 4900. A bit pricy but it satisfies all my spraying needs.
It has a built-in pump and a two speed turbine. It comes with tips for fluid sets from #2 to #6. It has a two quart remote pot (great for tight spaces and spraying upside-down). I have used it for spraying stains, laquers, varnishes, urithanes, enamels, latex, acrylics, and other catalized products. I even sprayed the exterior of my garden shed with thick exterior latex using the #6 tip. For larger projects I hook up my 2 gal. pressure pot and use my larger compressor. This for me is the most diverse, flexible, portable and expandable unit I've used.
Check it out
