Hello all,
I’m considering going from hand brushed to buying a HVLP Sprayer system. To begin with what should I be looking for in a good system? And can anyone suggest one that has worked well for them?
…I’ll be making my own booth as well but before I start will I need a completly enclosed booth with a HVLP system?
Thanks in advance
Couple of questions: do you have a compressor and, if so and assuming it has sufficient CFM's, I would go with HVLP conversion gun. I have both systems and if I was starting over a conversion gun and good compressor would be my first choice. A moderately-priced conversion gun gives as much control as HVLP and even greater control when compared to many inexpensive HVLP systems. The thing I dislike most about the conversion system is the noise from the compressor compared to the HVLP turbine.
The need for a spray booth really depends on what materials you are spraying, the size of the piece(s) and your work area. Slow-drying materials should be sprayed in an enclosed area since the atomized particles are not dry when the hit the surrounding surfaces. Since I primarily spray lacquers, this is not a problem. I either spray them outside or move them from the shop to the garage and spray them there. I always use a respirator regardless of where I spray. If I must spray in the shop, unless it it is a really small piece, I curtain-off an area by hanging plastic sheet material from the ceiling to reduce the atomized particles from settling on the tool surfaces. I open windows in the shop for cross-ventilation which is usually sufficient to get rid of the fumes.
Doug
Thanks for that information, I do have a compressor, a big one at that so I think it'll put out enough CFM's. So this narrows it down a bit to conversion guns.Your comments have saved me a lot of time (and money) researching HVLP turbines, thanks for that.pqken
I have three HVLP compressor guns (out of 9 total), and have used several more. Sata's guns are Great, but use a lot of air. The best all around gun I have used is the Asturo Eco/S. but it's in the $400+ range. My next favorite is the Binks Mach1 with the 94/94P air cap and needle combo, also not cheap.
If you are not into spending a lot of money but still want professional quality performance, look at the guns by Astro (not asturo). They have a gravity cup gun that sells for around $80, and you can get a pressure feed setup for around $150, and they perform right up there with the high dollar stuff. Porter-Cable's PSH-1 gets great reports, too, although I haven't used it. both use about 8 CFM maximum @40 PSI.
Michael R
try http://www.compliantspraysystems.com and http://www.homesteadfinishing.com they will give you the answersBuck Construction View Image
Artistry in Carpentry
Pgh, PA
I've got a Husky gravity-feed HVLP gun that I got from HD for about $80. I've used it for polyurethane, but now spray only lacquer with it. It works just fine for me.
Bill Arnold - Custom Woodcrafting
Click Here if you're interested in a good,inexpensive website host.
